  3. How to keep a custom command active until ESC is pressed...
  • Subscribers 150
  • Views 15319
How to keep a custom command active until ESC is pressed ?
Kinkar
Kinkar over 10 years ago
I have written a script to put contact at the overlap of two metals. But the command works only once. If I want to put contact at the next overlap I need to call the function again.
So, how could I keep the command active till ESC is pressed like copy, create path commands ?
- Gopal
  • psill000
    psill000 over 10 years ago
    What is the input command to invoke your script; enterPoint, select box, etc
    What I have done if an enterPoint() was have a while loop
    Ex:
    while(repeat
                    unless(loop repeat = nil)
                    if(deGetEIP(cw) then
                            pt      = geWindowToEditPoint(cw enterPoint(?noInfix t))
                    else    pt      = enterPoint(?noInfix t))
                    if(geCoordp(pt) then
                            ;;;;;;;;;;;;;;;;yourScriptOrSomthing;;;;;;;;;;;;;;;;
                    else    repeat = nil)
    Paul
  • Kinkar
    Thanks Paul.
    I got the logic. Its working now as per the requirement.
    But I couldn't understand the purpose of  below statements:
    1.  unless(loop repeat = nil)
     2.  if(deGetEIP(cw) then
    -Gopal
  • psill000
    The loop variable is an input variable for the script. I have the script setup for one and done and continuous.
    The edit place point is different than getting the point from enterPoint
    Paul
