  3. facing a problem in creating a via in Virtuoso 6.1.6-64...
  • Views 15844
facing a problem in creating a via in Virtuoso 6.1.6-64b
Heywire
Heywire over 10 years ago
I am trying a create a via object using skill command in Virtuoso 6.1.6-64b.  I have written code as below-
cvId = geGetEditCellView()
tech = techGetTechFile(cvId)
viaDefId = techFindViaDefByName(tech "M1_M2")
And then obtaining the via parameters from already present via by selecting it and using following commands-
a=geGetSelSet()
viaParams=a~>viaHeader~>overrideParams
And when I try to use the below command to create a new via at the same location,  I getting warning message back.
newVia = dbCreateVia(cvId viaDefId car(a~>origin) car(a~>orient) viaParams)
*WARNING* (DB-270585): dbiListToStdViaViaParam:via parameter 1 - Invalid parameter for the viaDef.
nil
Please let me know where I am going wrong.
Anand
    Hi Anand,
    This is because geGetSelSet() returns a list of selected objects, and so viaParams will be a list of the sets of parameters - so there is one too many list present. You can either pass car(viaParams) to dbCreateVia (as you've done with the orient and origin) or better would probably just to do:
    a=car(geGetSelSet) ; look at just the first object
    newVia = dbCreateVia(cvId viaDefId a~>origin a~>orient viaParams)
  • Heywire
    That works beautifully. Thanks for the help.
    Anand
