  3. Check LVS for Pcell
  • Replies 17
  • Subscribers 148
  • Views 27893
Check LVS for Pcell
NguyenDinh
NguyenDinh over 10 years ago
Hi all, I am a newer in Pcell. I designed a Pcell and run LVS, and had errors. I show  it below. Can anyone help me? Thank!
*** Calibre Interactive: Exporting netlist for library "skill", cell "example", view "schematic" ***
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.01s.
Loading cdf.cxt
*WARNING* Invalid CDF data entry
*Error* cdfiCreateParam: Invalid CDF data entry.
*Error* load: error while loading file - "/home/outsource4/PDK/cdf_res_new.il" at line 114
function spcInputDim redefined
*Error* eval: undefined function - pcDefinePCell
*Error* load: error while loading file - "/home/outsource4/PDK/skill_res5.il" at line 124
function spcMsg redefined
function spcSetParam redefined
function spcRound redefined
function spcInputInt redefined
function spcCalcRes redefined
function spcCalcLength redefined
function spcDefResLength redefined
function resCB redefined
function res_spacingtretchCB redefined
function res1 redefined
function res_nodd redefined
function res_even redefined
function res_finanl redefined
Running Artist Hierarchical Netlisting ...
ERROR (OSSHNL-109): The cellview 'skill/example/schematic' has been modified since the last extraction. Validate
that the schematic is correct and run Check and Save to correct this error.
End netlisting Mar 17 17:58:32 2016
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
    It looks as if you're loading the code to create the pcell and the CDF again (from the libInit.il in the library?). You do not need to do this. Once the CDF has been created it is stored in the cell's data.dm and once a PCell has been created, the code is stored in the cellView itself.
    The only things that need to be loaded each time are any additional functions that are used within CDF callbacks or are called from within the body of the pcDefinePCell call - the code that forms the body is stored in the cellView, but any user-defined functions called from within the body are not.
    Because you're trying to redefine the CDF and pcell each time, you either might have permission problems are be trying to create them in an executable that doesn't have all the necessarily functionality available.
    By the way, sending me a friendship request with the same question is not a way to get an answer to a question. I don't accept friendship requests in the forums unless I genuinely know the person well or have explicitly asked somebody to in order to be able to send some direct info to me; I cannot answer direct questions from anyone the world over because I don't have the bandwidth and it rather defeats the point of having a community forum.
  • NguyenDinh
    Thank for your help. These errors has gone. But have another error, below:
    "*Error* Cell: res in library: PDK is missing a simInfo section in it's CDF for the current simulator."
    Have you any ideal for this error?
    Looking forward from you soon,
    This means that whilst you might have defined CDF for the component res in library PDK, you've not defined the simulation information (simInfo) for the simulator/netlister that you're using. This is needed to tell the netlister how to netlist the component - which terminal order is needed, which parameters need to be netlisted, and so on.
  • NguyenDinh
    Thank you so much, Andrew
    Have you a nice day !
  • NguyenDinh
    I have another issue, when I run LVS. I have some errors, below:
    LVS completed. NOT COMPARED. See report file: example.lvs.report
    LVS completed. CPU TIME = 0 REAL TIME = 0 LVHEAP = 67/91/91 MALLOC = 59/59/59 ELAPSED TIME = 0
    ERROR: Corresponding cells could not be identified.
    ERROR: Nothing in layout.
    *** Calibre finished with Exit Code: 4 *** "
    I have researched in cadence forums and I know that I have not created any pin. So, I use a function to create pins, I show below:
    minus = rodCreatePath(
    ?layer "M1"
    ?cvId pcCellView
    ?width w
    ?pts list(caar(contactLeft~>dbId~>bBox):
    (abs(abs(cadadr(contactLeft~>dbId~>bBox))- abs(cadar(contactLeft~>dbId~>bBox)))/2 + cadar(contactLeft~>dbId~>bBox))
    caadr(contactLeft~>dbId~>bBox):
    (abs(abs(cadadr(contactLeft~>dbId~>bBox))- abs(cadar(contactLeft~>dbId~>bBox)))/2 + cadar(contactLeft~>dbId~>bBox)))
    ?pin t
    ?pinLabel t
    ?pinLabelLayer list("M1" "pin")
    ?pinLabelHeight 0.5
    ?termName "MINUS"
    ?termIOType "inputOutput"
    But  the result is not changed. I do not why. May I wrong, am I ?. Would you help me ?
    Thankyou
    I can't help you with a Calibre problem (it's a Mentor Graphics tool that I don't have access to) and anyway I don't have  your data either. The message "ERROR: Nothing in layout" is a bit suspicious though - not sure it's anything to do with not having pins. I suggest you read the entire log file and maybe contact Mentor about it.
  • NguyenDinh
    Thank you for your helpful
  • NguyenDinh
    Hi Andrew, I have another problem. When I use "Edit CDF" (tools -> CDF -> Edit) to change CDFparameters, I apply it and my functions work perfectly. But when I turn off CIW then open it again. All CDFparameters (that I changed before) have gone. How could I resolve this problem? Would you help me? . Thank you
    You need to change the CDF Type to "Base" rather than "Effective" before making the changes. Otherwise the changes are in memory only.
  • NguyenDinh
    Thank you so much, it's working now
