  3. Query exact command of syntax check for Behaviourals
  • Views 14690
liorscotland
liorscotland over 10 years ago
Hello all. The context is as follows:
We want to run batch syntax checks for text views (mostly verilog, systemVerilog and VerilogAMS). The trouble is that the views have no write access. Hence, the vmsUpdateCellView() SKILL command cannot be used. The issue is that there are multiple settings for running the verilog/verilogAMS engine. These include syntax checkers, verilog 2001 support, and others.
The question is: How can one query the ncvlog/ams designer/other engine call for checking a particular cell WITHOUT actually calling the skkill vmsUpdateCellView() SKILL command
    Hi Lior,
    Could you please log this through customer support? I'm not sure of the answer off the top of my head (bit short of time to do the research myself today) - but one of the team here could certainly handle that question.
  • liorscotland
    Hi Andrew. Will do. Thanks.
