  3. Layer Panel in app form
  • Views 15505
gaurc
gaurc over 10 years ago
I want to display layer panel (palette) as a field in a form creted using hicreateappform. So I can select a layer when the form is opened. How to do it?
    You can use hiCreateLayerCyclicField to create a field which allows you to choose a layer, but that's not the same as embedding the whole palette in your form (which you can't do, and I'm not sure that's what you want).
    Regards
  • gaurc
    Thanks for the response Andrew.
    hiCreateLayerCyclicField() has syntax :-
    d_techFileId
    t_fieldPrompt
    t_callback
    l_layers
    [l_LPpair]
    [s_fieldName]
    we should pass a list for the l_layers, we can use leGetValidLayerList() but it works only when a layout view is opened. Is it possible to pass the layer list without opening a layout view?
    i.e. :-
    leGetValidLayerList(techGetTechFile(geGetEditCellView()))  -------> when a layout view is opened
    ?   ?  ?        -------------> when layout view in not opened
    Regards
    GaurC
    How about this:
    tf=techGetTechFile(ddGetObj("libName")); could pass cellView id too
    validLPPs=foreach(mapcar lpp setof(lp tf~>lps techIsLPValidBase(lp)) list(lpp~>name lpp~>purpose))
  • gaurc
    Thanks a lot Andrew.
    Regards
    Chandan
