  3. Create MPP using custom template
  • Subscribers 150
  • Views 17147
DenisAdamcho
DenisAdamcho over 10 years ago
I would like to start creating an MPP with a pre-selected template using SKILL. So instead of clicking "Create MPP" and then changing the template the user could start drawing using the custom template that was created earlier.
When launching the lxHiCreateMPP() it starts an enter function so it is impossible to change the value of the template field using SKILL once its running.
Only solution I can think of is to create the form that is used for the MPP(leRodMppForm) in the background and change the value of the field that specifies the template used(rodMPPTemplate).
Is there a way to create this form without starting the enter function? Or is there a different approach that can be used to solve this problem?
Denis
  • psill000
    psill000 over 10 years ago
    Not sure I understand what you want, but here might be starting point for to work on
    procedure(myMpp(opt)
    leRodMppForm~>rodMPPTemplate~>value= opt
    leHiCreateMPP()
    ); end of myMpp
    The above script will change the mpp template, but you need to load the file with all your mpp templates.
    Some potential bugs with this script.
    1) You need to load the template file. You can do it manually when you start the session or have a script load the template.
    2) The template gui may not be generated when you first execute the command and get a warning/error about an unknown form.
    Paul
    I can modify Paul's code a little:
      hiEnqueueCmd(sprintf(nil "leRodMppForm~>rodMPPTemplate~>value=%L" opt))
      leHiCreateMPP()
    ); end of myMpp
    Then I can do myMpp("N-Tap") or whatever the template is called. This will then work the first time you use the command too - because of the hiEnqueueCmd call (which will execute once the enter function has started.
  • DenisAdamcho
    hiEnqueueCmd worked perfectly!
    Thanks for your help!
