  3. Skill code to add decaps/fillers in empty spaces
  • Subscribers 150
  • Views 3563
wuntzang
wuntzang over 10 years ago
Hi all,
I am just new to skill code and my knowledge is not that broad for now. I want to test something, adding some cells (decaps or dummies to any empty areas in my top level). I tried using the leLayerAndNot in which I used the prboundaries for my lists.. but I think this function could not detect shapes or objects inside a cell, only flatten ones..
thanks and regards,
wuntzang
  • skillUser
    skillUser over 10 years ago
    Take a look at Solution 20316611 for filling a rectangular area with instances of another cell.  For using the layer functions through the hierarchy take a look at Solution 11237840 for a way to do that.
    Hope this helps!
    Lawrence.
  • Guruprasad S
    Guruprasad S over 10 years ago
    Hi Lawrence ,
    Can you please attach the Solution 20316611 , Solution 11237840   in reply . That would be very helpful .
    Lawrence can't do this - it's content behind the support login.
    You should be able to get a login - even if you're a university. There's a process for this, as is outlined in this post in the academic network group. For mainstream customers you just need the hostid of your license server to register an account.
