  3. Regular Expression: detecting 2 or more consecutive spaces...
  • Replies 7
  • Views 29188
Regular Expression: detecting 2 or more consecutive spaces oddity
Sheppy
Sheppy over 10 years ago
For a particular script I have to check whether or not a string has two or more consecutive spaces between lower-case characters. Zero and one space are allowed, two or more not. I am using rexMatchp() to check. Please have a look at the following code+output:
rexMatchp("[a-z][ ]{2,}[a-z]" "test test")
nil
nil
nil
rexMatchp("[a-z][ ][ ]+[a-z]" "test test")
nil
t
t
The three last commands do exactly what I want. However, the first three do not work, although this is perfectly legal syntax for a regular expression. I found in the Virtuoso documentation that using {} to specify the number of occurrences is supported, but it clearly doesn't work in my example.
Am I doing something wrong?
With kind regards,
Sjoerd
    Sjoerd,
    You need to use pcreMatchp, not rexMatchp. The documentation for rexMatchp doesn't talk about this extended syntax - the old rex functions have very limited regular expression support, whereas the pcre functions have a very rich regular expression support. If you use pcreMatchp, the first returns nil (as it should) but the second and third return t.
  • Sheppy
    Thanks Andrew, I'll change the code to use the pcreMatchp procedure in stead. Kind regards, Sjoerd
  • Sheppy
    I keep having problems with the regular expression syntax in SKILL.
    This is the string with the special characters I want to check:
    regExprMatchPattern = "[a-zA-Z0-9`-=;'./~!@$%^&*()_+{}|:\"<>?]"
    When I used rexMatchp it works:
    rexMatchp( regExprMatchPattern previousChar )
    And it works like this as well:
    validLine = !rexMatchp( strcat( regExprMatchPattern "[ ][ ]+" regExprMatchPattern ) nextLine )
    However, when I replace rexMatchp with pcreMatchp or pcreCompile/pcreExecute, it doesn't work at all. There is a problem with the characters in the regExprMatchPattern. This is what I tried, and what doesn't work:
    validLine = !pcreMatchp( strcat( regExprMatchPattern "[ ]{2,}" regExprMatchPattern ) nextLine )
    OR
    rexPatternSingleSpace = pcreCompile( regExprMatchPattern )
    rexPatternMultipleSpace = pcreCompile( strcat( regExprMatchPattern "[ ]{2,}" regExprMatchPattern ) )
    printf( "%L - %L\n" rexPatternSingleSpace rexPatternMultipleSpace )
    validLine = !pcreExecute( rexPatternMultipleSpace nextLine )
    When I tried to find out which characters were causing the issue, I wrote a bit of code like this:
    testString = "[`-=;'./~!@$%^&*()_+{}|:\"<>?]"
    for( i 1 strlen( testString ) printf( "%L - %L\n" substring( testString i 1 ) pcreCompile( substring( testString i 1 ) ) ) )
    It showed that the characters *()+? are causing problems. After removing them from the testString, all pcreCompile() commands resulted in a pcreobjId.
    However, when I removed those characters from my code, it still did not work (not working for both pcreMatchp and pcreCompile/pcreExecute).
    It turns out that various combinations of characters are causing problems as well. That's where I stopt testing: there are thousands of combinations to test. A Google search did not return something useful.
    Can you help me to solve this regular expression problem (detecting all the characters in regExprMatchPattern)?
    Bonus question: how to detect [] in a regular expression (\[ and \] do not work)?
    I'm having issues with detecting EOF (End Of File) as well. The input file for my code is a CSV file, but some tools generate a CSV file without a EOL/LF/NL/CR (End Of Line/Line Feed/New Line/Carriage Return) at the end. The values at the end of the file should be processed as well.
    Below you'll find the actual code and an example input file (I couldn't find a button to attach some files...).
    The code works like it has to work with the given example. Some lines are commented-out, at two points, just replace the ; to get the other cases. Remember: if line 1 is used at location 1, then line 1 must be used at location 2 as well, 2 & 2 and 3 & 3 of course.
    The code (stripped down, the processing of listCellList is removed):
    procedure( testLineRead( inFileName "S" )
        let( (    ( inPort nil )
            ( lineNr 1 ) ( nextLine "" ) ( lineLength 0 ) ( validLine nil )
            ( previousChar "" ) ( currentChar "" ) ( nextChar "" )
            ( cell "" ) ( cellList nil ) ( listCellList nil )
            ( regExprMatchPattern "") ( rexPatternSingleSpace nil ) ( rexPatternMultipleSpace nil )
            ( i 1 )
            printf( "debug: %L - %L\n" rexPatternSingleSpace rexPatternMultipleSpace )
            when( isFile( inFileName )
                inPort = infile( inFileName )
                when( inPort
                    while( gets( nextLine inPort )
                        lineLength = strlen( nextLine )
                        previousChar = ""
                        currentChar = ""
                        nextChar = ""
                        cell = ""
                        cellList = nil
                        ;;; location 1: reg-expr. test lines (3):
                        ;validLine = !pcreMatchp( strcat( regExprMatchPattern "[ ]{2,}" regExprMatchPattern ) nextLine )
                        ;validLine = !pcreExecute( rexPatternMultipleSpace nextLine )
                        unless( validLine
                            warn( "Illegal number of spaces ( >1 ) in cell value detected - (%s - line %d), please fix!" inFileName lineNr )
                        ) ;;; end of unless
                        while( validLine && i <= lineLength
                            currentChar = substring( nextLine i 1 )
                            nextChar = substring( nextLine i + 1 1 )
                            cond(
                                ;;; Filter out all white spaces or tabs...
                                ;;; But a bit more complicated than that: a valid value may contain spaces, but NEVER at the start or end.
                                ;;; A valid value may be "M1 path", the space between "M1" and "path" MUST NOT be removed.
                                ;;; location 2: reg-expr. test lines (3):
                                ( ( currentChar == " " && rexMatchp( regExprMatchPattern previousChar ) && rexMatchp( regExprMatchPattern nextChar ) )
                                ;( ( currentChar == " " && pcreMatchp( regExprMatchPattern previousChar ) && pcreMatchp( regExprMatchPattern nextChar ) )
                                ;( ( currentChar == " " && pcreExecute( rexPatternSingleSpace previousChar ) && pcreExecute( rexPatternSingleSpace nextChar ) )
                                    cell = strcat( cell currentChar )
                                    previousChar = currentChar
                                ;;; All other whitespaces and tabs must be filtered out...
                                ( ( currentChar == " " || currentChar == "\t" )
                                ;;; Filter out empty lines...
                                ;;; An empty line may contain whitespaces, but no valid characters.
                                ( ( currentChar == "\n" && cell == "" && cellList == nil )
                                    warn( "Empty line (%s - line %d) detected, please remove..." inFileName lineNr )
                                    i = lineLength
                                ;;; Filter out all comments (a comment is all after a #)...
                                ;;; When the line only contains a comment, with or whithout whitespaces left of the #...
                                ( ( currentChar == "#" && cell == "" && cellList == nil )
                                    i = lineLength
                                ;;; When the line contains a comment after one or more valid cells (with or without whitspaces in-between)...
                                ( ( currentChar == "#" && cell != "" )
                                    cellList = append( cellList list( cell ) )
                                    i = lineLength
                                ;;; When the line contains a comment AND the last non-whitespace character was a "," (with or without whitspaces in-between)...
                                ;;; If the last non-whitespace character was NOT a "," "cell" would have had a value and thus the previous condition would have been true.
                                ;;; The current value of "cell" is therefor "" (empty string) thus it is safe to add this to the "cellList".
                                ;;; If there is a ",", there is at least 1 cell in cellList, either a valid cell value or ""
                                ( ( currentChar == "#" && cellList != nil )
                                    i = lineLength
                                ;;; Detect the comma's that separate the values (that's why it is a CSV-file...)
                                ;;; If the first valid character of the line is a ",", so previousChar = "", with or without whitespaces
                                ;;; If empty in-between two ","'s (so no valid character(s))...
                                ( ( currentChar == "," && ( previousChar == "" || previousChar == "," ) )
                                    cell = ""
                                ;;; Empty in-between a comma and new-line, so add "" to the list...
                                ( ( currentChar == "\n" && previousChar == "," )
                                    cell = ""
                                ;;; A comma, and none of the special things in front of it, so construct the new cell...
                                ;;; A new-line, and none of the special things in front of it, so construct the new cell...
                                ( ( currentChar == "," || currentChar == "\n" )
                                    cell = ""
                                ;;; Everything else must be part of a valid value...
                                ( t
                            ) ;;; end of cond
                            i++
                        ) ;;; end of while validLine && i
                        when( cellList
                            println( cellList )
                            listCellList = append( listCellList list( cellList ) )
                        validLine = nil
                        i = 1
                        lineNr++
                    ) ;;; end of while
                    close( inPort )
                ) ;;; end of when inPort
            ) ;;; end of when isFile
            println( listCellList )
        ) ;;; end of let
    ) ;;; end of procedure testLineRead
    The Example input file, make sure that after the last line no EOL/LF/NL/CR is present:
    #This is a comment
     #This is a comment after a single whitespace
    abc#This is a comment after a valid cell value
    ,def#This is a comment after a valid cell value
    ghi,jkl #This is a comment after two valid cells and a whitespace
    ghi , jkl #This is a comment after two valid cells and a whitespace
     mno,pqr #This is a comment after a whitespace, two valid cells and a whitespace
    ,#This is a comment after a single ",", thus two "NA"'s
    ,,#This is a comment after two ","'s, thus three "NA"'s
     , , #This is a comment after two ","'s, thus three "NA"'s
    ,stu,#This is a comment after two ","'s, thus three "NA"'s
     ,vwx, #This is a comment after two ","'s, thus three "NA"'s
    #empty lines above, with and without spaces...
    yza,bcd,efg
     hij, klm , nop ,
    qrs,tu vw,xyz
    012,34 56,789
    012,34   56,789,abc # This should give a warning that there are too many spaces
    012,34$ ^56,789 # this is valid
    012,34" '56,789 # this is valid
    # The following line should be added to the output, but I don't know how to check for End of File without New Line...
    noNewLineAtEndOfFile
    Many thanks in advance.
    With kind regards,
    Sjoerd
    Hi Sjoerd,
    Was a bit difficult to see the wood from the trees in all of this - but the key problem is the "-" character in the pattern. The trouble is that this is being interpreted as a "range" separator - in fact pcreCompile gives a warning to that respect.
    So if you do this:
    pattern = "[`\\-=;'./~!@$%^&*()_+{}|:\"<>?\\[\\]]"
    ;pattern = "\\S"
    testString = "`-=;'./~!@$%^&*()_+{}|:\"<>?[]"
    pat=pcreCompile(pattern)
      printf( "%L - %L\n" substring( testString i 1 ) pcreExecute(pat substring( testString i 1 ) ) )
    You'll see it works (notice the double backslash before the - in the expression - you can do the same in your main code of course). It's a double backslash, because SKILL also uses backslash to escape characters in strings, and backslash is an escape character in regular expressions, so to get an RE \ you need \\. I also answered the bonus question of how to add [] inside the [] - escape them (see the end of the pattern).
    Note you could also use \\S (see "man perlre" for info on Perl regular expressions) but maybe you want to exclude particular characters - you could use other complex ranges though maybe to make it simpler.
    In order to detect a non-carriage-return terminated line, I just added this to your code:
    printf("READ %L NEWLINE %L\n" nextLine pcreMatchp("\n" nextLine))
    The pcreMatchp would return nil for the last line in the file if it didn't have a carriage return (or rather newline) at the end.
    It wasn't entirely clear what the expected output of your program was, but hopefully the above will give enough pointers in the right direction.
  • Sheppy
    Thank you very much Andrew.
    Using the pattern you suggested I got the exact output I want to have. And thank you for pointing me in an obvious direction: in stead of detecting the last line without a "\n" and then still trying to get the correct values out of it, I did the following (adding directly after while( gets( nextLine inPort )):
    rexPatternNoNewLine = pcreCompile( strcat( "\n" ) )
    unless( pcreExecute( rexPatternNoNewLine nextLine )
        nextLine = strcat( nextLine "\n" )    ;;; Could have used sprintf()...
    ) ;;; end of unless
    So what I do now is adding a "\n" to a line that does not have a "\n" at the end. By first performing this action, I did not have to change anything to the cond() statement.
    Thanks for your time and support, regular expressions are still a bit "hocus pocus" for me.
    With kind regards,
    Sjoerd
    Hi Sjoerd - one little point. Put the pcreCompile outside the while loop - there's no need to recompile every time around (you might as well just use pcreMatchp if you're going to do that). Regards, Andrew.
  • Sheppy
    Hi Andrew, after posting my previous reply I did exactly that: all three pcreCompile statements are grouped together and outside the while-loop. Kind regards, Sjoerd
