  3. Timeout a procedure within SKILL
  • Views 15843
mp133786
mp133786 over 10 years ago
Within a SKILL procedureA, I am calling another SKILL procedureB.  In a normal scenario, procedureB should finish within 20-30 seconds.  If I want to terminate the procedure execution after X minutes, how would I do that?  IpcBeginProcess starts a new process and I don't want that.  Is there a timeout type feature for a skill procedure call?  Thank you.
procedure( myProcedureA()
   myProcedureB() ; <<<< want to terminate the procedure if not done within some time limit.
) ; end myProcedureA
procedure( myProcedureB()
   ;; do bunch of stuff
   ;; stuff should be done within 20-30 seconds
   ;; Terminate the procedure if not done within some time limit.
) ; end myProcedureB
    No, SKILL is single threaded, so this can't be done (currently). You'd have to get the code to monitor its own time and abort itself if it was taking too long.
  • dmay
    dmay over 10 years ago
    I have done this before in a procedure that had a while loop. In some cases it would be run on large sets of data and needed to stop. Basically I put a check in my loop to see if a pre-defined time limit had been exceeded.
    timeLimit = 30 ; seconds
    while( ...
    curTime=stringToTime(getCurrentTime())
    elapsedTime=curTime-startTime
    when(elapsedTime > timeLimit
    code to quit
    OR
    code to prompt user if they want to continue
    Since the above code takes a few small processing cycles, I actually only did that check once every 50 times through the loop using a counter and the modulus command.
    j=0 ; outside the loop
    j++ ; inside the loop
    when(integerp(timeLimit) && mod(j 50)==0
    myExceedTimeLimitCheck()
    I hope this helps.
    Derek
    Hi Derek,
    That's precisely the kind of approach I was suggesting - the code being well behaved and checking itself rather than being controlled from outside. It's a bit like collaborative multi-tasking rather than preemptive multi-tasking (sort of).
