  3. ipcBeginProcess
  • Replies 7
  • Views 18640
ipcBeginProcess
ajni
ajni over 10 years ago
Hi
I am running
cid = ipcBeginProcess("/afs/btv/data/asicCDK/tools/test/noarch/bin/runCalibreDRC outputFile")
this runs calibreDRC using the controlfile.
after this ipc ends i need to execute the next step
if(ipcIsAliveProcess(cid)== nil then
printf("the gds is put in the below path\n /afs/btv.ibm.com/u2/narahish/fx14p/cadence/FILL\n"))
this does not work. i tried ipcWait also . But the next etep is executed before the ipc is completed.
Can i get a help on this.
  • ajni
    step*
  • skillUser
    skillUser over 10 years ago
    Use asynchronous mode so that the next job starts when the first one has completed, tracked by the exit handler. In other words, use the exit handler of the first job to start the second job. Regards, Lawrence.
  • ajni
    Thanks Lawrence.
    Do you have an example for asynchronous mode
    Try looking at this post. In fact there are numerous posts about ipcBeginProcess on these forums:
    Andrew Beckett
    Replied to: How to start these jobs one after another
    You can do this with the postFunc argument to ipcBeginProcess - to chain the various submissions. To make this simpler, I wrote the code below which can be seen as a little package for job submission.…
    By Andrew Beckett over 10 years ago in Cadence Technology Forums > Custom IC SKILL
  • skillUser
    Doesn't anybody read or search the manuals these days?
    Asynchronous input/output SKILL coding example with ipcBeginProcess.  Specifically look at the 'simTerm' procedure and how it is referenced from ipcBeginProcess.
    Lawrence.
    Lawrence,
    It's very difficult to find the Help menus in Virtuoso. Somebody sneakily labelled them "Help". They even hid a search box there too in recent versions.
  • ajni
    Thanks a lot.
