  3. warning of Acde in Cadence Virtuoso
  • Views 16006
Anum Khan
Anum Khan over 10 years ago
Hello Sir,
I am Anum Khan i am working on a project of designing a Low Power Low Noise Op-amp on Cadence Virtuoso version IC6.1.5.500.12
when i run the simulation it gives the warning of 'Acde' = 240.24e-03 is unusually small.
Can you please explain what does Acde means and how can i fix it ?
Thank You
Best Regards,
Anum Khan
    Anum,
    This is not a SKILL question, so for future reference this is in the wrong forum (unfortunately due to a temporary bug I can't move it to the right place).
    This is likely to be a model parameter, and from a quick hunt, I think it's for bsim4. Looking at the bsim4 help:
    244 acde=1.0 m/V Exponential coefficient for charge thickness in CAPMOD=2 for accumulation and
        depletion regions.
    I suspect it's a problem with your device models - I can't tell for certain without seeing it (you didn't say which spectre version you're using, because the versions I tried didn't give exactly that warning).
    You might want to check with the foundry that supplied the models (and check with a recent MMSIM version).
  • Anum Khan
    Dear Sir,
    I am sorry for posting m question in a wrong forum. I will be careful for the next time.
    The spectre version i am using is 11.1.0.214 and the technology is LFoundary 0.15um
    Warning from spectre during initial setup.
    WARNING (CMI-2419): M9.pmos1v8lvt: `imax' = 1 A is larger than `imelt' = 10.9 mA. `imelt' is increased to `imax'.
    WARNING (CMI-2424): M9: `Acde' = 240.24e-03 is unusually small.
    WARNING (CMI-2419): M10.pmos1v8hvt: `imax' = 1 A is larger than `imelt' = 10.9 mA. `imelt' is increased to `imax'.
    WARNING (CMI-2424): M10: `Acde' = 240.24e-03 is unusually small.
    WARNING (CMI-2419): McascP.pmos1v8hvt: `imax' = 1 A is larger than `imelt' = 10.9 mA. `imelt' is increased to `imax'.
    WARNING (CMI-2424): McascP: `Acde' = 240.24e-03 is unusually small.
    WARNING (CMI-2419): M8.pmos1v8hvt: `imax' = 1 A is larger than `imelt' = 10.9 mA. `imelt' is increased to `imax'.
    WARNING (CMI-2424): M7: `Acde' = 240.24e-03 is unusually small.
    Is there any solution for this?
    Anum Khan
