  3. skill code to find out VIA coordinates from given layou...
  • Subscribers 152
  • Views 20144
skill code to find out VIA coordinates from given layout
Gunwant
Gunwant over 10 years ago
Can someone tell me skill code to extract VIA locations from given layout ? e.g I have metal 5 and metal 6 in my layout and i m mainly interested in knowing VIA5 locations. Is there skill code to get this ?
  • skillUser
    skillUser over 10 years ago
    Gunwant,
    I don't know which version you are using and that's important because earlier versions and current versions of Virtuoso represent vias differently. Assuming that you are using something recent (IC61x or ICADV12x) then vias are represented as objects in a layout - from the cellview database ID you can get the vias (e.g. geGetEditCellView()~>vias). From there you can get the types and locations - here's an example for showing me M4_M3 via locations:
    setof(via geGetEditCellView()~>vias via~>viaHeader~>viaDef~>name=="M4_M3")
    => (db:0x29c9ca9a db:0x29c9ca9b db:0x29c9ca9c db:0x29c9ca9d db:0x29c9ca9e
    db:0x29c9caa5
    setof(via geGetEditCellView()~>vias via~>viaHeader~>viaDef~>name=="M4_M3")~>xy
    => ((0.0 0.0)
    (7.58 0.0)
    (7.58 3.585)
    (3.325 4.515)
    (7.605 7.585)
    (0.0 2.215)
    If you are asking about just the via layer cut shape then you can get to that too, but you'd need to transform the shape from the master to the current location, but I'm not even sure that's what you're asking for (your question is fairly vague).
    I hope this helps,
    Lawrence.
  • Sheppy
    Sheppy over 10 years ago
    Hi Gunwant,
    Please find below a little procedure that goes through all cells in a given library and reports a few details about vias in a cellview.
    procedure( extractViaInformationInLibrary( libName "S" )
      let( ( ( libDbId nil )
        ( cellName "" )
        ( viewName "" )
        ( cellView nil )
        ( viewType "" ) )
        printf( "Going through all cells in library %L to find via's and report their details...\n" libName )
        ;;; Getting the information (database ID) for the library...
        libDbId = ddGetObj( libName )
        ;;; Search in all cells of given library, if library exists...
        when( libDbId
          foreach( cell libDbId~>cells
            cellName = cell~>name
            foreach( view cell~>views
              viewName = view~>name
              cellView = dbOpenCellViewByType( libName cellName viewName nil "r" )
              viewType = dbGetq( cellView cellViewType )
              when( equal( viewType "maskLayout" ) && cellView~>vias
                printf("This is a valid cell-view WITH vias: %L %L %L\n" libName cellName viewName )
                foreach( via cellView~>vias
                  printf( "    Via details: type = %L | origin = %L | orientation = %L | connectivity = %L\n" via~>viaHeader~>viaDefName via~>origin via~>orient via~>net~>name )
              ) ;;; end of when viewType
            ) ;;; end of foreach view
          ) ;;; end of foreach cell
        ) ;;; end of when libDbId
        t
      ) ;;; end of let
    ) ;;; end of procedure extractViaInformationInLibrary
    Load the code and run it by doing this:
    extractViaInformationInLibrary( "your_library_name" )
    This will give you some information about all vias in the library.
    With kind regards,
    Sjoerd
  • Gunwant
    Hi Lawrence,
    Thanks for your reply. As of now,I need just VIAcoordinates for running reliability flow. For some reason your code is not giving all via co-ordinates. I am using ICADV12x.
  • Purge2343
    Purge2343 over 6 years ago in reply to Sheppy
    Hey
    is it possible to use the same structure to get the metal information?
    Andrew Beckett over 6 years ago in reply to Purge2343
    What do you mean by "metal information"? I'm assuming that since you asked another question in this post, we'll discuss it there instead.
