  3. skill code to generate pin list
  • Subscribers 150
  • Views 21655
SteveRFIC
SteveRFIC over 10 years ago
I have a cadence layout with lots of pins at different locations. I want to generate a list of the pins, ideally with the following information
pinname, location (X,Y coordinates), pin layer.
The pins are all in rectangular shapes, so ideally I want the locations of the center of those rectangulars.
Is this doable by using existing Layout or Layout XL commands, or by using skill?
I found some information to print a list of the labels from the following post, but could not get the file generated. nothing happens when I load the skill code :(
https://community.cadence.com/cadence_technology_forums/f/48/t/27295
Sorry that I am a circuit designer and not very familiar with SKILL, any help is highly appreciated.
Thank you!
  • RK56
    RK56 over 10 years ago
    Is this is what you are asking for?
    foreach(term geGetEditCellView()~>terminals
    foreach(pin term~>pins
    printf("%s\t%L\t%L", pin~>net~>name, centerBox(pin~>fig~>bBox), pin~>fig~>lpp)
    RK
  • SteveRFIC
    Thank You Ramakrishnan!
    This works and it is exactly what I want.
    I wanted to print this into a file by adding the following two lines at the proper locations. I could only see an empty file generated. But if I use printf, then I can see the pinlist printed in CIW. It seems that fprintf is not working for me. Really don't know why. Any suggestion? Thanks!
    myPort=outfile("./pinlist")
    fprintf(myPort "\n%s\t%L\t%L" pin~>net~>name centerBox(pin~>fig~>bBox) pin~>fig~>lpp)
  • Sheppy
    Sheppy over 10 years ago
    Hi Gang Liu,
    You should not forget to tell in what mode you want the file to be opened/created.
    Please have a look at this very simple piece of code:
    procedure( printToFileTest( fileName printString "SS" )
        let( ( ( myPort nil ) )
            myPort = outfile( fileName "w" )
            fprintf( myPort "File name: %s\n" fileName )
            fprintf( myPort "Print string: %s\n" printString )
            close( myPort)
        ) ;;; end of let
    ) ;;; end of procedure printToFileTest
    Load this code and do for instance:
    printToFileTest("./test.tst" "hello world")
    This should result in a file with two lines in it.
    Please make sure you close the port at the end. This is a must.
    With kind regards,
    Sjoerd
  • SteveRFIC
    Thank you Sjoerd! I tried your code and it works fine.
    After comparison, I found that I forgot to close ( myPort). When I added this line after the fprintf function, then I got the file with printed pin list.
    Problem solved.
    Thank you Ramakrishnan and Sjoerd!
