  3. skill mode download?
  • Views 16708
drdanmc
drdanmc over 9 years ago
I used to use an emacs skill mode which had some very useful features like il-query-localize-block-vars (I think I typed that right, auto-complete was my friend).  Is this still available somewhere?  Searching the forums only turned up some other implementations which seemed to have some context highlighting and IPC communications to icfb but without some of what I liked in the past like the local variable stuff.
-Dan
  • skillUser
    skillUser over 9 years ago
    Hi Dan,
    I'm fairly sure there should be someone at Cadence that can supply the emacs SKILL mode to you but it is most likely out of date in that it will not contain the newer functions or reflect any changes that may have been made to existing function APIs. Is that what you are looking for? I don't use emacs and I don't think that I have a copy of the emacs SKILL mode, sorry.
    Lawrence.
    Historically I've asked people to send me a private message with their email details (actually you have to send a friend request because my profile is such that I only allow private messages from "friends" because I don't want people to bypass the forums and just send me questions directly - I don't have the bandwidth to deal with that). However, since the change in the formatting of the forums and main Cadence site, I can't find out how you'd do that - so I'm trying to find out.
    Given that I still get occasional random friend requests, it must be possible - I'm just not sure how currently.
    Once I find out, I'll tell you what to do Dan (or I'll contact you directly via a request). I can send you the existing (old) SKILL mode for Emacs that Lawrence refers to.
  • FormerMember
    FormerMember over 9 years ago
    Hello Andrew,
    Even I couldn't find a way to send you private message to share my email id. Can you please suggest, how to get the skill mode for emacs?
    Jayesh
    Jayesh,
    Hover your mouse over my photo in this thread, and you should get a popup window with "Follow" and "Request Friendship". Click on the Request Friendship choice, and in your request please explain that you are after the SKILL mode for Emacs and what your email id is. I'll probably deny the friend request (this is to cut down the number of direct requests I get, because it's not possible for me to handle the volume of direct requests I already get), but I will use that info to send you the SKILL mode.
