  3. How to access global signals cds_globals
  • Subscribers 148
  • Views 5954
FormerMember
FormerMember over 9 years ago
Hello everyone,
I have a cellview that has both inherited connections that can be called with this command dbGetCellViewInheritedSig and other global signals that do not show up with it. However, all of them appear in the cds_globals module after the netlisting.
I want to figure out this global "hidden" signal without running the netlister. Like is there a way in skill to get the name of this signal?
Sherif
    Sherif,
    Not quite clear what you're after here, but for a specific cellView you can find the global signals this way:
    setof(sig cv~>signals sig~>isGlobal)~>name
    (obviously you don't need to do the ~>name if you just want the db objects). Note that global signals are defined per-cellView, so to find all in the design, you'd have to do this for each cellView in the hierarchy.
  • FormerMember
    Thanks Andrew for your reply. The thing I myself don't know what actually that signal is to describe it properly. I mean it should be a global signal since it has the ! attached to it and it ends up in the cds_globals module. But to describe it a bit clearer, I will try and approach it like this:
    So a top cell has a main voltage source that is defined as nsub!, it goes all the way down with the hierarchy with each cell. Whenever you define a source and give it the name nsub, it will be hooked up to this global signal. However, every other block/CV will have its own inherited connections. If you apply this line to the cv: dbGetSigNetExpr(id) where the id is the id of the schematic view, you will get the inherited connections in this block. And although you can still access nsub from within that block, you cannot find it between the signals or the inherited connections. Now if you run the netlister from the AMS options menu, you will see the nsub with the other inherited connections listed there.
    My problem is that I want to get this nsub from within that small block.
    I hope I did it right this time :)
    Sherif
