  3. break string without losing any character from string
  • Views 16481
Sharif H N
Sharif H N over 9 years ago
Hello team,
I want to break a string at particular intervals without losing any character.
I can use parseString to break the string, but I will loose the delimiter. And I need to concatenate it again.
Is there any way to break a string without losing any character, other than parseString?
For ex: string= "CustomSKILL". I want the output to be ("CUSTOM" "SKILL").
Thanks in advance
Sharif
  • skillUser
    skillUser over 9 years ago
    Hi Sharif,
    I think this is what you are looking for:
    substring(
      S_string
      x_index
      [ x_length ]
        => t_result / nil
    Creates a new substring from an input string, starting at an index point and continuing for a given length.
    If you have a lot of processing to do, consider doing it outside of SKILL; in my opinion SKILL is not well suited to doing a lot of text manipulation.  Having said this, I am generally able to do the text processing that I need using functions like the above substring and length, and the pcre* prefix functions (and sometimes rexMatchp)
    Best regards,
    Lawrence.
