  3. Export GDS and CDL using command prompt
  • Subscribers 150
  • Views 21399
anandmohan
anandmohan over 9 years ago
HI,
1) I am using cadence version IC6.1.7-64b.500.7. I just need to know, how to streamout GDS and export CDL using command prompt (for example calibre can be executed by "calibre -drc -hier calibre.drc" directly in linux command prompt). From CIW window  File > Export > Stream/CDL will give the same, but I need to know how to do it from linux command prompt.  Please tell me how to do it.
2) Also is it possible to execute a skill code in CIW window using a perl script?
Regards
Anand
  • drdanmc
    drdanmc over 9 years ago
    For stream out, the command line utility is 'strmout' You can either specify all of the options like lib/cell/view name, output file, mapping files, etc on the command line or use 'strmout -templateFile <filename>' to give the options in a template file. See the "Design Translation Using XStream Translator" section of the Design Data Translator's Reference manual. For GDS out, it is 'si -batch -command netlist' that you need. That will look for a 'si.env' file that has all the setup. See that same manual but the section on "Design Translation Using CDL Out". Half the battle sometimes is getting to the right manual!
    For the second question, please give some insight into what you want to execute from a perl script. I already gave an answer in another thread which pointed you at the "skillServer" solution for doing this, so presumably you need something else? Or maybe that answered your question.
    (this was a response to the original question, not to Dan's response which was right on the money).
  • anandmohan
    HI Dan,
    Thank you for the reply, I will try this .
    Regards
    Anand Mohan
  • anandmohan
    HI Andrew,
    My requirement is to write a perl script which will take library name & top cell name as input, then it will generate GDS based on my inputs and executes calibre drc automatically using the generated GDS ( basically DRC automation ). I am new to cadence & I thought the only way to generate is through skill. I will try to execute it based on inputs given by Dan. Thank you very much for your help.
    Regards
    Anand
