  3. ADE-XL plot graphs by reading data from the database
  • Views 15718
netbug
netbug over 9 years ago
Dear all,
I have an ADE-XL with several tests and I would like to plot specific waveforms of each test, which have been specified by the user. I was wondering if it is possible to access the database of each run and get the data.
A different question but related
When I select a given test on ADE-XL, let's say STB I get the following command in the log file: _axlTestFilterChanged(axlOutputsForm4->axlOutputsWidget4 "'(\"STB\")")
Cadence appends a number to the commands, in this case 4. This seems to be different from one ADE-XL session to another. So, when coding, how can I get this number ?
Best regards,
Pedro
    Pedro,
    If it's scalar data you want, that's easy enough to do with axlReadHistoryResDB(). For waveforms, it's rather more complicated - see this thread:
    pkerichang
    Accessing ADEXL outputs from Ocean
    Hello, So I ran a parametric sweep with ADEXL and sets a history tag name. Then, later in Ocean I use axlReadHistoryResDB() to load the simulation results from that history, and use the ResDB data structure…
    By pkerichang over 9 years ago in Cadence Technology Forums > Custom IC SKILL
    Latest by Andrew Beckett over 9 years ago
    You certainly wouldn't do it by trying to reconstruct the expressions you get in the CIW, with the unique numbers on the end - that's definitely the wrong way to do it. That's intended purely for log file replay reasons, not for code that is trying to automate tasks procedurally.
