  3. Launching ADE L fails when simulator set to eldoD_sp in...
  • Views 15414
Launching ADE L fails when simulator set to eldoD_sp in cds.env
SacStateMS
SacStateMS over 9 years ago
I have installed IC617, Mentor Graphics AMS and Artist Link to integrate Eldo simulator with Virtuoso. I have followed the installation steps carefully as per the documentation. I have set  "eldoD_sp" as the default simulator in .cdsenv.
When I try to launch ADE L from Schematic Editor window, ADE doesn't open and I see following message in command window.
*WARNING* hiCreatePulldownMenu: The menu must contain at least 1 entry
*Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
<<< Stack Trace >>>
(... in sevHiSetDisableCallback ...)
(... in sevHiCreatePulldownMenu ...)
(... in sevPulldownMenu ...)
(... in unknown ...)
(... in sevCustomMenus ...)
(... in sevMainWindowPulldownMenus ...)
(... in sevCreateMainWindow ...)
(... in sevStartSession ...)
(... in sevSchematicArtistPulldownMenus ...)
apply(artSchematicArtistPulldownMenusFunc() list(args))
let((simulatorchosen design) if(((args->window)->sevSession) then (simulatorchosen = sevSimulator(((args->window)->sevSession))) else (design = sevDesignInSchematic((args->window))) ... ) cond(((simulatorchosen == "ams") unless(deFindPlugin('amsaAMSPlugin (args->window)) _artInstallPlugin((args->window) 'amsaAMSPlugin))) (rexMatchp("Verilog$" simulatorchosen) unless(deFindPlugin('artVerimixPlugin (args->window)) _artInstallPlugin((args->window) 'artVerimixPlugin))) (t when(deFindPlugin('artVerimixPlugin (args->window)) deRemovePlugin((args->window) 'artVerimixPlugin)) when(deFindPlugin('amsaAMSPlugin (args->window)) deRemovePlugin((args->window) 'amsaAMSPlugin)) when(deFindPlugin('ddsgHEDPlugin (args->window)) deRemovePlugin((args->window) 'ddsgHEDPlugin)))) apply(artSchematicArtistPulldownMenusFunc() list(args)))
(... in _deApplyTrigger ...)
funobj@0x18ddaf48()
(... in _dePullTrigger ...)
(... in _deCallMenuTrigger ...)
(... in __deMakeBannerMenus ...)
(... in __deInstallNewAppInWindow ...)
(... in __deInstallApp ...)
(... in deInstallApp ...)
deInstallApp(hiGetCurrentWindow() "analogArtist-Schematic")
*WARNING* (DEBASE-102079): A SKILL error occurred in function artMenuTrigger
 If the default simulator is set to "spectre", ADE can be launched. But as soon as "eldoD_sp" is set as simulator in the setup menu, the same error occurs and the menus in the menubar disappears on ADE L window.
Could anyone point me in right direction to figure this problem out. I had just one custom skill file in the setup and I have disabled loading of it in .cdsinit to make sure it wasn't the reason for this error.
Ashwin
SacState MS lab
    Ashwin,
    I think  you'll need to contact Mentor Graphics about this, since the integration of Eldo in ADE is their code.
