  3. Find paths an MPPs
  • Subscribers 150
  • Views 15585
Find paths an MPPs
RVERP
RVERP over 9 years ago
I want to write a script that searches all the paths in my layout (level0). But if I look for shaps with objType "path", the MPP's are also included. How can I see the difference between a path and a MPP?
  • psill000
    psill000 over 9 years ago
    Sorry I am going from memory, so I can be wrong.
    MPP are rod objects. Use this function to determine if it is a MPP
    rodIsObj(objDb)
    Paul
  • RVERP
    Hello Paul, I already tried that option. I selected a MPP (just one) and executed rodIsObj(car(geGetSelSet())), but it returns nil.
  • skillUser
    skillUser over 9 years ago
    Try this instead: rodIsObj(rodGetObj(car(geGetSelSet()))) or even just rodGetObj(car(geGetSelSet())) as it will return nil for a regular path. Be aware that instances will return a rodObj if using this code, so you may need to ensure that the selected objType is a path first.
    Also you could look at, say, the subParts to verify that the shape is an MPP:
    mpp = rodGetObj(car(geGetSelSet()))
      => rodObj:0x444cad00
    mpp~>subShapes
      => (db:0x838500a4 db:0x838500a5)
    Hopefully this will help you.
    Best regards,
    Lawrence.
