  3. Turning off grid and track by default
  • Views 18861
GDCRA
GDCRA over 9 years ago
I want to turn off grid and track by default in layout editor. Can someone tell me lines to be added in .cdsenv file? I am suing ICADV 12.3
  • skillUser
    skillUser over 9 years ago
    Hi Gunavant,
    I'm not sure that you can actually do this with a .cdsenv, however, you could write a layout view trigger that runs the following code:
    pteSetVisible("Grids" nil "Grids")
    pteSetVisible("Tracks" nil "Grids")
    I haven't got time to find a specific example of a view trigger but look for deRegUserTriggers() and you should find some code examples either in this forum or on Cadence's support pages.
    Best regards,
    Lawrence.
  • skillUser
    Also, I have not tried this but you might just be able to save the Workspace set up to a custom (user-defined) name and make that your default, I think the settings should be stored. The docs hint this: "The Palette configuration settings can be saved as part of a Virtuoso workspace."
