  3. Running 2 procedures or function in 1 bindkey
  • Replies 7
  • Subscribers 150
  • Views 17923
GDCRA
GDCRA over 9 years ago
I was spying on skill command in CIW when I am doing some graphical actions such as clicking netlistcreat form and clicking "Apply" in order to create netlist.
I thought I will able to create keybinding to run this step, so I was trying
hiSetBindKey("Schematics" "<Key>F12" "xcreateNetlist() _hiFormApplyCB(xcreateNetlistForm)")
But its on working. For some reason, it get stucked at 1st stage of opening form. When I close this form, it perform 2nd part of nestling. So its waiting for something between step 1 and step 2.
Can someone help here ?
  • RK56
    RK56 over 9 years ago
    I preference for such cases would be to use hiReplayFile(). There is also hiEnqueueCmd() which I'm not familiar with much
    -Ramakrishnan
  • skillUser
    skillUser over 9 years ago
    Most likely the form is blocking, so as soon as it is displayed the code afterwards (applying the form callback) doesn't get executed. I think that Ramakrishnan may be correct in that you can use hiEnqueueCmd():
    hiSetBindKey("Schematics" "<Key>F12" "hiEnqueueCmd(\"_hiFormApplyCB(xcreateNetlistForm)\") xcreateNetlist()")
    However, it is often better to look for an API that is not dependent on the form/GUI - can you investigate what the form callback is and see if you can call that directly? [You may not be able to do this if the callback depends on the form structure and the values collected there].
    Best regards,
    Lawrence.
  • GDCRA
    Thank you much Lawrence. Solution you provided is working.
    On side note, how do I find out form callback ? I may need this for my other work.
  • fatcat1206
    fatcat1206 over 9 years ago
    Hi Gunavant
    You may use the following trick to get the callback in a form.
    1. Call out the form.
    2. use command "form1 = hiGetCurrentForm()", to fetch the object for the form.
    3. check the property of the form, simply by "~>" operator, like "form1~>?"
    4. "_doneAction" indicates the callback function for "Apply" or "OK", like "form1~>_doneAction"
    5. if you visited a "field" of the form, you will see the "_callback" property of it, like "form1~>field1~>_callback"
    Best Regards
    Yi
  • skillUser
    This is good but I have one small correction: the ~> operator should be used with database objects such as cellview id's, object id's, tech file id's, rod objects and so on, whereas the -> operator should be used with things like menu structures, form structures, window id's, disembodied property lists, tables and so on (essentially "anything else"). One benefit of the ~> operator is that it can accept a list of objects on its left-hand-side and can apply the same query to each of those objects in turn, collecting the results of each into the resultant list.  So in your example the ~> should ideally be changed to -> (it will still work).  I reserve the use of "~>" when dealing with db objects as noted earlier.
    Cheers,
    Lawrence.
    Hi Lawrence,
    <pedantryAlert>
    Whilst I tend to follow the convention you suggest (although generally speaking I write in LISP syntax rather than using operators at all, as you know), strictly speaking the only difference between ~> and -> is when the left-hand-side is a list.
    If the left-hand-side is a singleton object, they are equivalent. If the left-hand-side is a list, then -> treats the list as a disembodied property list; the ~> operator does an implicit "foreach mapcar" across the list - so in other words if you do theList~>prop it will return a list of all the resulting values that you'd get if you did ~>prop for each member of the list.
    </pedantryAlert>
  • fatcat1206
    Hi Andrew and Laurence
    Thank you for giving the insight of "~>" and "->". It's very helpful.
    I use "~>" more often, as when I read the "User Guide", it mentioned "~>" as generalization of "->".
    And during practice, I found "~>" is easier to use (works at most of the situations)
    I just try both of them on a disembodied proper list, and recall my memory that I use "->" for the DPL in the past, as "~>" fails.
    And with your explanation, I have a further understanding of the error message and why "~>" fails. Thanks again.
    Best Regards
    Yi
