  3. SIN function
  • Views 18756
SIN function
jazzmatazz
jazzmatazz over 9 years ago
I try to use a sin function in order to draw some shape in the layout but it is strange why when I type sin(90) in CIW, the result is not 1 but 0.893.. ?
Where I wrong :)
jazzmatazz
    Andrew Beckett over 9 years ago +1
    That's because the argument should be in radians, not degrees. The example in the documentation (SKILL Language User Guide) makes that pretty obvious... deg=90 defMathConstants('myConsts) sin(deg*myConsts…
    deg=90
    sin(deg*myConsts.PI/180.0) => 1.0
    (the defMathConstants is a convenient way of referencing a variety of useful constants without needing to type them in).
  • jazzmatazz
    Radians! :)
    Thanks for the explanation Andrew.
    Nikolay
  • jazzmatazz
    One more question. What syntax should I use to be able calculate something like this sin^-1(1234) ( sine on power of minus 1 ) ?
    I try with sin**-1(1234) but it's not working.
    Nikolay
    Do you mean asin() (i.e. the arc sine)?
    So you either want asin(1234) or if you really meant to the power of -1 then it would be sin(1234)**-1 or 1/sin(1234)
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    Sorry , I am writing in existing request . This is Just to say thank you because i was looking for the same function to have correct value of Pi.
    Regards
    Sonu
