  3. skill code to place all layout cells in a Virtuoso lib to...
  • Replies 12
  • Views 27243
skill code to place all layout cells in a Virtuoso lib to top level cell
mantang
mantang over 8 years ago
Hi
I would like to instantiate all layout cells in a lib to newly created top cell and run DRC on all cells at the same time. Each layout cell cannot be overlapped in the top cell.
Does anyone have SKILL code or similar code to achieve this goal ?
ManChak
    /* CCFplaceAllInstances.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 01, 2017
    Modified
    By
    Place an instance of each layout in a library into a cellView
    examples
    CCFplaceAllInstances(?libName "stdcellLib" ?viewName "layout" ?columns 20
       ?spacing 2.0)
    CCFplaceAllInstances(?cv cvId ?libName "stdcellLib" ?spacing 4.0)
    SCCS Info: @(#) CCFplaceAllInstances.il 12/01/17.06:33:20 1.1
    *      CCFplaceAllInstances(@key (cv geGetEditCellView())      *
    *         libName viewName (spacing 5.0) (columns 10))         *
    *    Place an instance of every layout from library libName    *
    *  with view viewName (or if viewName not specified, pick all  *
    *   maskLayout view types from the library) in rows with up    *
    * to columns instances per row. Additional spacing (specified  *
    *    by the ?spacing argument) is added between instances.     *
    procedure(CCFplaceAllInstances(@key (cv geGetEditCellView())
        libName viewName (spacing 10.0) (columns 10))
      let((master masterDdId (x 0.0) (y 0.0) maxY width height (column 0))
        ; Iterate over all cells and views in the library, and either pick the
        ; matching viewName or views with type maskLayout
        foreach(cell ddGetObj(libName)->cells
          foreach(view cell->views
            master=nil
            if(viewName then
              when(view->name==viewName
                master=dbOpenCellViewByType(libName cell->name viewName)
            else
              masterDdId=ddGetObj(libName cell->name view->name "*")
              when(masterDdId && ddMapGetFileViewType(masterDdId)=="maskLayout"
                master=dbOpenCellViewByType(libName cell->name view->name)
            when(master
              ; Place instance, and then increment position based on size of
              ; the instance placed
              destructuringBind(((llx lly) (urx ury)) master~>bBox
                width=urx-llx
                height=ury-lly
                maxY=if(maxY max(maxY height) height)
                dbCreateInst(cv master "" x-llx:y-lly "R0")
                column=mod(column+1 columns)
                if(zerop(column) then
                  x=0.0
                  y=y+maxY+spacing
                  maxY=nil
                else
                  x=x+width+spacing
                dbClose(master)
        t
  • mantang
    mantang over 8 years ago in reply to Andrew Beckett
    Thank you for your code.
    ManChak
  • annesha
    annesha over 6 years ago in reply to Andrew Beckett
    I am trying out this code and getting an error that says argument missing
    Andrew Beckett over 6 years ago in reply to annesha
    If you provide the actual error message, there's a chance that I might be able to help you. Without that I have no idea if there's something wrong with the code, or something wrong with how you've entered the code, or something wrong with what you're doing.
    Please also provide the sub-version of the IC tools you're using (what Help->About shows).
  • annesha
    This is error message showing:
    *Error* CCFplaceAllInstances: extra arguments or keyword missing - ("ibm" "layout" "20" "2.0")
    <<< Stack Trace >>>
    CCFplaceAllInstances("ibm" "layout" "20" "2.0")
    (... in leHiCreateInst ...)
    leHiCreateInst()
    version being: CADVM18.1-64b.500.10
  • annesha
    annesha over 6 years ago in reply to annesha
    This is how the function call was made:
    CCFplaceAllInstances("lib_name" "layout" 20 2.0)
    It's defined as a keyword argument function, and so you can't pass positional arguments. You'd need to do:
    CCFplaceAllInstances(?libName "ibm" ?viewName "layout" ?columns 20 ?spacing 2.0)
    (as shown in the comments at the top of the code). Missing out the ?libName, ?viewName etc keywords won't work.
  • annesha
    Thanks a lot!
  • Srikanth51
    Srikanth51 over 6 years ago in reply to Andrew Beckett
    I am seeing following ERROR when i run the command
    CCFplaceAllInstances(?libName "work_test" ?viewName "layout" ?columns 20 ?spacing 2)
    *Error* dbCreateInst: argument #1 should be a database object (type template = "ddgltxg") - nil
    Andrew Beckett over 6 years ago in reply to Srikanth51
    You either need to run it with a layout window open and the current window (which is not the case for you, because otherwise the ?cv argument to the function would have had the default value of geGetEditCellView() - if that is returning nil, it means there is no current window for it to place the instances into), or you need to pass ?cv cvId where cvId is the database id of the cellView you're trying to place the instances into.
    If you're trying to do this from batch (without any windows open),  you'd do:
    cvId=dbOpenCellViewByType("mylib" "allCells" "layout" "maskLayout" "w")
    CCFplaceAllInstances(?cv cvId ?libName "work_test" ?viewName "layout" ?columns 20 ?spacing 2)
