  3. skill code to place all layout cells in a Virtuoso lib to...
  • Replies 12
  • Views 27244
skill code to place all layout cells in a Virtuoso lib to top level cell
mantang
mantang over 8 years ago
Hi
I would like to instantiate all layout cells in a lib to newly created top cell and run DRC on all cells at the same time. Each layout cell cannot be overlapped in the top cell.
Does anyone have SKILL code or similar code to achieve this goal ?
ManChak
  • Srikanth51
    Srikanth51 over 6 years ago in reply to Andrew Beckett
    Thanks @andrew..  for the quick response
    It worked with the layout opened
    To do in a batch mode .. Can you send me updated skill code with the updates
    Andrew Beckett over 6 years ago in reply to Srikanth51
    The code doesn't need updating. It works as-is (i.e. as posted back in 2017), and I gave an example of how to do this in batch mode in my last reply. The code was already designed to be used either with an interactive window, or a specified cellView id.
