  3. Create a combo field with layers?
  • Views 17016
fungibleChattel
fungibleChattel over 8 years ago
I’d like a combo field like the one in the newest layout property editor’s LPP field. A combo field where there are cyclic options and you can type into it. But the hiCreateComboField only takes a list of text options, not icons. How can a user create a similar field?
  • mbracht
    mbracht over 8 years ago
    You need to use hiCreateLayerCyclicField() - only drop of bitterness is you cannot type into it. Not sure whether there is any way to achieve this.
  • fungibleChattel
    fungibleChattel over 8 years ago in reply to mbracht
    That is what I am currently using, but the ability to type in the layer name also is what I’m looking for. The list of valid layers is a bit too daunting.
    Andrew Beckett over 8 years ago in reply to fungibleChattel
    The function that you need to use is leCreateLayerField. That's the function that provides the extended combo-box which allows typing in as well as selection via a drop-down list.
  • fungibleChattel
    fungibleChattel over 8 years ago in reply to Andrew Beckett
    Thanks, Andrew, I never would have looked at the le* functions for that. I appreciate your help.
