  3. Extract Device Properties Using SKILL
  • Views 17132
KGh94
KGh94 over 8 years ago
In the library manager, it is possible to right click on a cell (e.g. a transistor) and "Show Properties". I need to retrieve one of the values included in the properties (e.g. max_Width, with value 100u).
I have tried dbGetPropByName(instID, "max_Width"), but it seems like this is not the function I need as it returns nil.
Any hints would be appreciated.
Best regards,
Karam
    Andrew Beckett over 8 years ago +1
    Hi Karam, If it's on the cell, then you'd need to do: bag=dbOpenBag(ddGetObj("theLibName" "theCellName")) prop=dbGetPropByName(bag "max_Width") prop~>value Or (particularly if you're not changing…
    Hi Karam,
    prop~>value
    Or (particularly if you're not changing it, and the property name doesn't have any spaces or unusual characters), you can just do:
    ddGetObj("theLibName" "theCellName")~>max_Width
    to get the value.
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Thanks Andrew, that's exactly what I needed!
