  3. How to Swap Source and Drain terminals using SKILL ?
  • Replies 7
  • Subscribers 150
  • Views 23957
Marben
Marben over 8 years ago
Hi All,
How to swap the source and drain of a pmos in layout using SKILL ?
because I can not find the S D swap button in the Property - Parameter of IC617.
Best regards,
Marben
    Andrew Beckett over 7 years ago in reply to FormerMember +1
    Hi Olivier, You normally do this by setting the permuteRule in the auLvs simulation information in the base CDF for the cell (the lib/cell for the pCell in question) to (p D S). Search in cdnshelp for…
    Hi Marben,
    The presence (or not) of an "SD swap" parameter on a device is a function of the PDK, not the tool version. It's completely dependent upon whether the foundry you're using have provided such an option.
    There is (in VLS XL) the ability to do Connectivity->Pins->Permute to swap around the source and drain pins, provided that the component has been set up to mark the S and D pins as permutable - again, that is a function of the PDK (we need to know if it's legal for the pins to be permuted, as otherwise you could permute the gate with the drain, for example). The permute capability works with any device with an permuteRule on it, not just MOS devices.
  • Marben
    Marben over 8 years ago in reply to Andrew Beckett
    You are right.
    I am now using the Connectivity->Pins->Permute to swap around the source and drain pins.
    Thank you very much.
    Best regards,
    Marben
  • FormerMember
    FormerMember over 7 years ago in reply to Andrew Beckett
    How to setup pcell code in order to have S and D permutable ?
    Best regards,
    Olivier
    Hi Olivier,
    You normally do this by setting the permuteRule in the auLvs simulation information in the base CDF for the cell (the lib/cell for the pCell in question) to (p D S). Search in cdnshelp for "permuteRule" (or use the search box at the top of the help menus in Virtuoso to find this). One good place in the documentation that describes this is in the "Troubleshooting Layout XL Compliance".
  • FormerMember
    Thank you, it works fine !
    Kind regards,
    Olivier
  • Olivia Li
    Olivia Li over 5 years ago in reply to FormerMember
    Hi Olivier,
    Do you know how to setup permutable of device. When I use connectivity-->permute to permute the S and D of device, the permute information shows "Cannot permute pin's' and pin'd' because the 'permuteRule' property on the instance disallows it ", thanks.
    Best Regards,
    Olivia
    Andrew Beckett over 5 years ago in reply to Olivia Li
    Hi Olivia,
    I explained this two posts above in this thread - here.
