  3. Punch holes in ROD object
  • Views 15288
snee
snee over 7 years ago
I have a ROD object, metal filled with contacts. I need to take this ROD object and ouch holes, evenly spaced through the middle of this shape. The hole should remove the metal, and any contacts whcih overlap the hole.
I tried following this solution, but  it will not remove the contacts as desired.
https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/37170/how-to-cut-an-array-of-rectangles-in-a-big-rectangle
Shane.
    Hi Shane,
    Depending on whether the shapes are choppable in the multi-part ROD object, you might be able to use rodAddMPPChopHole. Otherwise you could use an approach as in that article, but use rodUnNameShape first to convert it from being a ROD object into a collection of non-ROD objects. This will stop ROD from keeping it as a self-consistent multi-part ROD object.
