  3. How to push the contents of CIW window to a file on execution...
  • Views 3546
How to push the contents of CIW window to a file on execution of a skill script. May be something similar to "tee" command in Linux
Abhjith
Abhjith over 7 years ago
I just want to move everything that is printed on the CIW window on execution of any SKILL command. So is their any SKILL function to do this.
I know these things will be captured in the CDS.log file which will be created on opening the Virtuoso, But the CDS.log file has everything that o do in Virtuoso, and my intention is to capture the lines that are printed on execution of the custom SKILL function.
Thanks in Advance
Regards
Abhijith
    Hi Abhijith,
    A couple of possibilities. One simple approach is to call hiStartLog("file.log") before the operation and then hiEndLog() after the operation - that will create a second temporary log file with the log data between the two calls. Another could be to use the macro in the recent post: Redirect poport to variable
  • Abhjith
    Abhjith over 7 years ago in reply to Andrew Beckett
    Thanks for your support on this. I tried first method and its works fine for me.
    Regards
    Abhijith
