  3. Unable to create multiple pins in symbolview using skil...
  • Views 15551
Unable to create multiple pins in symbolview using skill
lbodepu
lbodepu over 7 years ago
I thought that this code should work for creating multiple pins in a cell view.
cv=dbOpenCellViewByType("TEST_5" "test_3" "symbol" "schematicSymbol" "a")
procedure(CCScreatePin( portList directionList  cv )
let( (mysympin)
   mysympin = dbOpenCellViewByType("basic" "sympin" "symbol")
   i=0
   foreach(portName portList
          let( ( myterm mytermdir mypinfig)
          myterm = portName
         mytermdir = (nth i directionList)
         println(mytermdir)
        case(mytermdir
         ("input"
                           mypinfig=schCreateSymbolPin(cv mysympin myterm "input" 0:0 "R0" )      )
          ("output"
                              mypinfig=schCreateSymbolPin(cv mysympin myterm "output" 0:100 "R0" )      )
           (t
                               error("\nUnexpected terminal direction")      )
           );case
          ) ;let
            i++
          ) ;foreach
dbSave(cv)
);let
);procedure
I am calling the procedure CCScreatePin( '("IN" "OUT")  '("input" "output")   cv)
Somehow when i use "w" for cv = dbOpenCellViewByType it generates just a single pin. But "a" doesnt create anything
Is there anyway i can get multiple pins in the symbol
Lavanya
    Hi Lavanya,
    A few issues - the code was placing the pins at fixed locations (0:0 and 0:100) so all the input pins would have been on top of each other and the output pins on top of each other. If you'd fit the window having created the pins (in either "a" or "w") mode you'd have not seen anything because the pins were so far apart that they'd have been tiny dots on the screen. So it probably appeared to work because you opened the design when it was empty and so could see the origin - and hence only saw the pin at 0:0.
    The open mode (a or w) controls whether it throws everything away or not - so if you run the code several times with "a" mode you will just keep adding more pins. It certainly doesn't behave differently other than that.
    Also, rather than using nth to look up the corresponding direction, it would be better to use a foreach loop with two loop variables to loop over the name and direction lists together.
    I rewrote the code to step the location of the input and output pins - see the improved version below:
    cv=dbOpenCellViewByType("opamp090" "test_3" "symbol" "schematicSymbol" "w")
      let( (mysympin inY outY pinPitch)
        inY=0.0
        outY=0.0
        pinPitch=0.125
        foreach((portName mytermdir) portList directionList
          let( (mypinfig)
            case(mytermdir
              ("input"
                mypinfig=schCreateSymbolPin(cv mysympin portName "input" 0:inY "R0")
                inY=inY+pinPitch
              ("output"
                mypinfig=schCreateSymbolPin(cv mysympin portName "output" 1:outY "R0")
                outY=outY+pinPitch
              (t
                error("Unexpected terminal direction\n")
            );case
          ) ;let
        ) ;foreach
        dbSave(cv)
      );let
    );procedure
    CCScreatePin( '("IN" "IN2" "IN3" "OUT" "OUT2")
      '("input" "input" "input" "output" "output")   cv)
  • lbodepu
    lbodepu over 7 years ago in reply to Andrew Beckett
    Thanks Andrew
