  3. ?display "artParameterInToolDisplay('wglen)" is giving a...
  • Views 2068
?display "artParameterInToolDisplay('wglen)" is giving a problem
lbodepu
lbodepu over 7 years ago
Hi
I wrote a skill code to create a cdf for a cellview.
cdfCreateParam(cdfId , ?name "wglen"
                                      ?units "lengthMetric"
                                      ?prompt "wg_length(min=0.0m ,max=1.0m)"
                                      ?defValue "1e-05m"
                                      ?type "string"
                                      ?parseAsNumber "yes"
                                      ?parseAsCEL "yes" )
This code doesn't give any problem and I can see the param wglen in the Properties of the cellview.
However if I use wg_len, I could not see the wg_len in the properties. Is '_' a special character here?
Lavanya
    Hi Lavanya,
    It works fine for me. If I do:
    cdfCreateParam(cdfId , ?name "wg_len"
      ?defValue "1e-05m"
      ?type "string"
      ?display "artParameterInToolDisplay('wg_len)"
      ?parseAsCEL "yes"
    and also ensure that wg_len is in the instParameters in the spectre simInfo in the CDF:
    cdfId->simInfo->spectre = '( nil
      modelParamExprList nil
      optParamExprList nil
      opParamExprList nil
      stringParameters nil
      propMapping nil
      termMapping nil
      instParameters (wglen wg_len)
      otherParameters nil
      termOrder nil
      componentName subcircuit
      netlistProcedure nil
    Because you have the artParameterInToolDisplay display callback, that filters parameters which won't be net listed by your current simulators.
