  3. Which function in IC 5.1.41 corresponds to dbCreateVia(...
  • Subscribers 148
  • Views 15962
Which function in IC 5.1.41 corresponds to dbCreateVia() in the IC 6.1.6 version?
yankunRen
yankunRen over 7 years ago
劳驾!
IC 5.1.41中的哪个函数对应于IC 6.1.6版本中的dbCreateVia()?
我试过db CreateVia(), IC 5.1.41中没有这样的功能。
请帮我。
谢谢!
  • mbracht
    mbracht over 7 years ago
    The underlying database in IC5141 was CDB (as opposed to OA) and vias were not separate database object...they were instances of cells. So the corresponding function would be dbCreateInst(..) for fixed cells and dbCreateParamInst(..) for PCells.
    Max
    Andrew Beckett over 7 years ago in reply to mbracht
    Also (I may update the community guidelines to say this), I would strongly encourage  you to post in English as you're much more likely to get a response if you do that.
    Kind Regards,
  • yankunRen
    yankunRen over 7 years ago in reply to mbracht
    Dear mbracht.
    Thank you very much for your help, I am trying this function and hope to succeed.
    Kind Regards,
    yankun
  • yankunRen
    yankunRen over 7 years ago in reply to Andrew Beckett
    Dear Andrew.
    I am very sorry, I forgot to switch languages, thank you for your reminder.
    Kind Regards,
    yankun
    Andrew Beckett over 7 years ago in reply to yankunRen
    Hi Yankun,
    No problem. I'm always impressed at how good engineers are at communicating in English across the world! (I have a certain inbuilt advantage by actually being English!)
