  3. Sorting list by sublist elements
  • Views 16111
climbnc
climbnc over 7 years ago
I have a list like the following
myList =(("I1" 0 0) ("I2" 2 1) ("I3" 1 1))
i would like to sort this list by the 2nd or 3rd element in the sublists.  the results would look like the following sorting by the 2nd element.
(("I1" 0 0) ("I3" 1 1) ("I2" 2 1)
can anyone help with this?  Your help is much appreciated.
Chris
    Hi Chris,
    myList=sort(myList lambda((a b) cadr(a)<cadr(b)))
    The lambda creates a temporary (nameless) function with two arguments (the two list items to be compared), and then the body of that function is comparing the 2nd element of each sublist (using the cadr).
    A word of caution: sort is a destructive function (changes the list in place) so make sure you use the return value of the sort function as otherwise slightly odd things can happen.
  • climbnc
    climbnc over 7 years ago in reply to Andrew Beckett
    Thank you Andrew for your help.
