  3. equivalent skill code for manually created schematic
  • Views 15911
PrasadAMSEng
PrasadAMSEng over 7 years ago
 is there any command to dump list of skill commands used while creating a given schematic ? Assume we have a schematic created manually , and now I want to list out all the skill commands virtuoso used in the background.
For example,  once ADE is setup then we can use "save ocean script" to list out all the equivalent ocean commands to dump into a file.
Thanks & Regards,
Prasad
  • mbracht
    mbracht over 7 years ago
    Hi Prasad,
    Use the SKILL function dbWriteSkill(..). Based on a given cell view (your schematic) it creates a file with the SKILL code to recreate just that cell view.
    Max
    Andrew Beckett over 7 years ago in reply to mbracht
    Note however that the functions in the dump produced by dbWriteSkill are low level database commands, and there are often simpler higher level functions that can be used such as schCreateInst, schCreateWire, schCreateWireLabel and so on which take care of some of the detailed work for you.
    There is nothing that dumps out a script using this set of functions though.
