  3. Require Skill code
  • Views 15733
Require Skill code
avi2412
avi2412 over 6 years ago
I want to check the via continuity at any layer. Can anyone guide me how to approach?
  • mbracht
    mbracht over 6 years ago +1
    Hi, Can you please elaborate on what exactly you mean with "via continuity"... Max
    Andrew Beckett over 6 years ago in reply to avi2412 +1
    What does "reaches extreme" mean? This is a very vague requirement. If you were trying to identify where there were insufficient bias, there is capability to do this with some of the Voltus-Fi analysis…
  • mbracht
    Max
  • avi2412
    avi2412 over 6 years ago in reply to mbracht
    Hi max,
    From top level/Instance Level, i want to check that whether the vias mostly V1(between metal1 and metal2) on power tracks has reaches extreme or still i can place more vias. So for that i want to Highlight Vias .
    Avinash
    If you were trying to identify where there were insufficient bias, there is capability to do this with some of the Voltus-Fi analysis options - this would then be based on ensuring that you are meeting current density, and also looking for too few vias and so on (Via coverage ratio, Skewed via ratio  as part of the "structural analysis").
  • avi2412
    avi2412 over 6 years ago in reply to Andrew Beckett
    Yeah I am looking for that only.Sorry for not able to clearly explain my question.
