  3. Issue with a SKILL code o/p
  • Views 3866
ssram
ssram over 6 years ago
I've got the following SKILL code to print the unbound instances in layout and schematic. But it does print something like
(db:0x3f1e409a db:0x3f1e471a db:0x2047469a db:0x317c9e1a db:0x20471f1a
db:0x2047259a db:0x2047251a db:0x3f1e441a db:0x3f1e499a
as well along with the ptintf. How to avoid this?
Ram
procedure(srFindUnboundInst()
myLib = geGetEditCellView()~>libName
myCell = geGetEditCellView()~>cellName
myview = geGetEditCellView()~>viewName
unboundInst(myLib myCell myview)
procedure(unboundInst(myLib myCell myview @optional (mylist list()))
let(( cv insts myMaster skipLibList)
skipLibList=list("basic" "analogLib" "US_8ths")
cv=dbOpenCellViewByType(myLib myCell myview "" "r")
insts = cv~>instHeaders
foreach( header insts
myMaster= header~>master
getWarn()
if( myMaster
then
if( member( myview myMaster~>cell~>views~>name) && !member(myMaster mylist) && !member(header~>libName skipLibList)
then
mylist = cons( myMaster mylist)
mylist=unboundInst(header~>libName header~>cellName if(cv~>cellViewType=="schematic" then myview else header~>viewName) mylist)
else
printf("Unbound Master: Library:%s, Cell:%s, View:%s, Missing From: Lib:%s, Cell:%s, View:%s\n"
header~>libName header~>cellName header~>viewName cv~>libName cv~>cellName cv~>viewName)
);if
);foreach
dbClose(cv)
mylist
);let
);procedure
hiSetBindKey("Layout" "Super<Key>F1" "srFindUnboundInst()")
    Your unboundInst function returns the list of unbound instances (see the mylist variable at the end). You need that because it's a recursive function. This is then called as the last function in srFindUnboundInst, and so it's the return value of srFindUnboundInst. I suggest that you change the function to:
      let((myLib myCell myview)
        t
    I also added in a let to declare some local variables to avoid myLib, myCell and myview becoming global variables. This function would now return t, and so when the return value is displayed in the CIW, it won't display the list.
  • ssram
    ssram over 6 years ago in reply to Andrew Beckett
    Thanks a lot Andrew, this works.
    Also, I've the o/p getting printed in the CIW, how can i print that in a pop-up window instead?
    Sooraj
    Andrew Beckett over 6 years ago in reply to ssram
    I updated your code to be able to write to a temporary file, and then display that in the main function:
      let((myLib myCell myview tempFile tempPort)
        tempFile = makeTempFileName("/tmp/missingInstances")
        tempPort = outfile(tempFile)
        unboundInst(myLib myCell myview tempPort)
        close(tempPort)
        when(fileLength(tempFile)>0
          view(tempFile nil "Unbound instances")
        deleteFile(tempFile)
        t
    procedure(unboundInst(myLib myCell myview @optional (outport stdout) (mylist list()))
          getWarn()
          if( myMaster then
            if( member( myview myMaster~>cell~>views~>name) && !member(myMaster mylist) && !member(header~>libName skipLibList) then
              mylist=unboundInst(
                header~>libName
                header~>cellName
                outport
                mylist
          else
            fprintf(outport "Unbound Master: Library:%s, Cell:%s, View:%s, Missing From: Lib:%s, Cell:%s, View:%s\n"
          );if
        );foreach
        dbClose(cv)
        mylist
      );let
    );procedure
  • ssram
    This is exactly what i was expecting, it works like a charm!
    Thank you so much Andrew.
  • mantang
    mantang over 6 years ago in reply to Andrew Beckett
    I do not understand the logic of "if" statement. Could you tell me the purpose of this line ?
    mylist=unboundInst(
                header~>libName
                header~>cellName
                outport
                mylist
    ManChak
    Andrew Beckett over 6 years ago in reply to mantang
    Hi ManChak,
    That was in your code in the first place! I did not write it.
    Presumably it's there so that if you cellView you're in is a schematic type, then it switches into the same view name as the current view (probably "schematic"). So for layouts it would switch into the view name instantiated; for schematic hierarchies you don't want to switch into the symbol but the corresponding schematic.
    However, as I said, this is not my code - it's yours...
