  3. Can't open my QRC (assura) Extraction Run Form
  • Views 2631
popoYoHo
popoYoHo over 6 years ago
My virtuoso is 6.1.8 -64b.500.6 and assura 4.1_USR6.
I have a trouble to open my QRC (assura) Extraction Run Form window. It is so wierd that I can open it sometimes. However sometimes, I can't open it and I didn't change any settings.
The error message is below:
Thanks a lot
    I found a current case where this is being investigated (case 46389742) which are describing similar symptoms. I wonder if somebody from the same institution as you has already filed this with customer support? Which Quantus version are you using? (in the UNIX terminal, type "qrc -version"))
  • popoYoHo
    popoYoHo over 6 years ago in reply to Andrew Beckett
    I am not sure if other people found this problem too. My QRC version is 19.1.3 -s062 (64bits). Yesterday I was stuck by this issue for 3 or 4 hours. Then at around 6pm EST time. It suddenly works after I keep refreshing "Quantus Parasitic Extraction Setup Form" window. However, it seems that settings in "Quantus Parasitic Extraction Setup Form" doesn't affect "QRC (assura) Extraction Run Form" window.
    Thanks.
    Andrew Beckett over 6 years ago in reply to popoYoHo
    In that case I suggest you contact customer support. It's going to be a challenge to figure it out here...
  • popoYoHo
    Okay.
    Thanks for the suggestion.
