  3. Execute skill script from unix shell
  • Subscribers 148
  • Views 18960
SrBraj
SrBraj over 6 years ago
I have completed my skill script which is working as designed when loaded via CIW. My script is just creating the library, then creating cells with schematic and layout view for all the components.
I want to execute the same script through unix shell without opening the virtuoso. What are the changes required to load my script through unix shell?
  • mbracht
    mbracht over 6 years ago
    Well you need some SKILL interpreter, how about
    % dbAccess -load yourSkillCode.il
    Max
    Andrew Beckett over 6 years ago in reply to mbracht
    As Max says, dbAccess will be OK if you are only using core SKILL, db, dd, tech, cdf functions; if you're using other more complex APIs you would need to run virtuoso. You could in that case do:
    virtuoso -restore yourCode.il
    or
    virtuoso -nograph -restore yourCode.il
    (you might then want to call exit() at the end).
