  3. Cadence-Python Interface
  • Replies 7
  • Subscribers 152
  • Views 37594
Curtisma
Curtisma over 6 years ago
Hello:
I would be interested in a Cadence-Python interface similar to the Cadence-MATLAB results interface.
Python has the same features available in MATLAB but is free and open-source.  It is also better for general computing and has a very diverse set of packages available.  In fact I am calling some python packages from within MATLAB and it would be better to have the option for a pure Python solution.
Should I submit a CCR through support?
Curtis
    Yes. Others have requested this too (not sure if there's a CCR - I didn't check). We have some partial Python interfaces for part of what's needed (e.g. waveform access) but not for the entire infrastructure that the MATLAB interface provides.
  • hmeyvaer
    hmeyvaer over 6 years ago in reply to Andrew Beckett
    Dear Andrew,
    Where can I find these partial Python interfaces for waveform access that you are mentioning? I would very much like to use them.
  • Curtisma
    Curtisma over 6 years ago in reply to hmeyvaer
    Hey hmeyvaer:
    Can you submit a request for this feature to Cadence support also? Having multiple requests will help make this a higher priority.
    Curtis
  • Martyniuk
    Martyniuk over 6 years ago in reply to Andrew Beckett
    Dear All,
    Any information regarding a Python interface for waveform access would be most welcome.
    My present, my flow runs simulations with Ocean, in order to save to my own data set files, and then the post processing is done with Python.  Maybe the Ocean step could be skipped with knowledge of how to use a Python interface?
    Best regards,
    Paul
  • Curtisma
    Curtisma over 6 years ago in reply to Martyniuk
    Hey Paul:
    Can you submit a request for a full Cadence-Python interface to Cadence support also? Having multiple requests will help make this a higher priority.
    Curtis
    Andrew Beckett over 6 years ago in reply to Curtisma
    To answer the various posts/requests in this thread...
    The python waveform reader interface is not shipped as part of the Virtuoso release and is effectively an early-access capability that's not formally released as part of the software yet. So any request would have to be via customer support, and given that it's a slightly special case, we'd need to ensure that you have the right licenses to use it, and to provide the kit and associated support.
    Note that the interface only takes care of waveform data and doesn't provide the integration with maestro views (e.g the SQL results database that maestro uses for the scalar results etc) that the MATLAB integration does, hence me referring to it as a "partial" solution.
    So I may have been a bit premature referring to it here...
  • eperez
    eperez over 6 years ago
    Hello, I'm not familiar with this interface with Matlab but it is currently possible to write a simple communication layer between Cadence and Python using ipcSkillProcess.
    The idea is that, since both Python and SKILL allow dynamic evaluation of expressions, one can launch a Python process that sends SKILL commands that in turn produce Python code with data objects. It is not particularly efficient since everything is encoded as text and evaluated at execution time, but it is still fast enough to handle large simulation waveforms or explore schematic hierarchies. It is also possible to have access to the full Cadence API by importing its SKILL functions wrapping them as Python objects and calling them from there, allowing one to create custom Python classes on top as needed. Except for error handling, which can be tricky as you're dealing with two outputs from the two interpreters, putting everything together to support most SKILL data types isn't very time consuming.
    Personally I think having this kind of interface at low level, with binary wrappers for these imports rather than going through eval(), would be extremely simple to implement and powerful enough not to care that much about whether a high level Python interface is eventually offered or not (for example you can just run your plotting scripts after simulating without needing Python expressions to be integrated in your ADEXL panel)
