  3. Annoying marker
  • Replies 7
  • Subscribers 152
  • Views 23255
Annoying marker
psill000
psill000 over 6 years ago
How do you get rid of this marker?
I know the remove marker deletes the marker, but I dont want it generated.
Paul
    Paul - what marker? I can see a tiny part of an info balloon in the right picture, but unless you provide more information I don't think anyone can help...
    Of course, the usual info about what tool you're using (VLS L, XL etc), which version and so on may also be important too. What is the pink circle object? Is that an instance? Is it a shape? How was it constructed? (may not need all of this, but without something to go on, not going to be able to help).
  • Colm D
    Colm D over 6 years ago
    Hi Paul,
    That's a connectivity mismatch glyph in Layout XL. Seems to have appeared in recent versions. A bit annoying to figure out what it is alright. Use Connectivity -> Check Against Source and untick the glyphys you don't want to see.
    Colm
    Andrew Beckett over 6 years ago in reply to Colm D
    Colm,
    Good point. The image was so zoomed in, I didn't immediately recognise this as a connectivity glyph (I was having a senior moment). You can also turn off the visibility in the annotation browser.
  • psill000
    psill000 over 6 years ago in reply to Colm D
    Thanks for the info and sorry for the image confusion. I dont see the glyphs in the menu selection. I am using EXL if that makes a difference ICADVM18.1-64b.500.6
    Andrew Beckett over 6 years ago in reply to psill000
    There's no UI control to turn off the glyphs - Colm was probably just suggesting that you could turn off the Connectivity switch on that form (although then you'll get no information from the check-against-source with respect to connectivity, so that's probably not desirable).
    There is an environment option to control this though, as covered in this article: How to control CAS on-canvas connectivity balloons in ICADVM18.1
    Simply, do:
    envSetVal("layoutXL" "casGlyphs" 'boolean nil)
    You'll need to re-do the check-against-source after disabling glyphs (i.e. turning it off doesn't alter the display of existing glyphs, but it does affect when they're recreated).
  • TallShark
    TallShark over 6 years ago in reply to Andrew Beckett
      So why did Cadence even create this? Who thinks that a GIANT pink circle that can't be seen through, can't be drawn through so you can't even DO the connection it's complaining about, steals cursor movements, is even remotely a good idea??  And then to not put a control for it in the XL options or another way to toggle it???
    Andrew Beckett over 6 years ago in reply to TallShark
    They're not normally giant - they alert you to the fact that you have check-against-source markers (and they only show if you've run check against source), and you can turn the display of them off in the navigator selectively. The idea is to give indication on the canvas that there are check-against-source issues. Here they don't seem excessively large to me (perhaps it depends on which check is being triggered). Yes, I know, this is a silly layout that's just been gen-from-sourced and I've not placed or routed anything yet:
    Some people like them, some people don't (clearly you don't). In current versions, you can control it on the form that pops up when you do check-against-source, so they're now easy to turn off when you run CAS (The Glyphs section at the bottom):
    As with all things - not everything appeals to everyone, and so we have an env var to change the default and a UI to change it on the fly.
