  3. Failed to import a cdl netlist
  • Views 18953
NickA
NickA over 6 years ago
I've been trying to import a schematic from a .cdl netlist file using the "Spice In" import option, and it's failing with the below spiceIn.log log. I can't see anything here that suggest what I'm doing wrong. Can you give me any ideas of what I could try?
Thanks very much,
Nick
Spice In Log File
Parameter file: /tmp/spiceInPp65558
Import Parameters:
Netlist file name: /home/nick/fuses/TEF018BCD64X1PI5_layout.cdl
Output library name: temp_nick
Output View Type: schematic
Schematic view name: schematic
Netlist view name: netlist_tmp
Reference Library List: tsmc18 temp_nick
Import Sub-circuit List: *
Top cell: TEF018BCD64X1PI5
Device-mapping file name: /home/nicholas.a/devMap
Master Cell for Ground: VSS
Cells to be Overwritten: <all>
Schematic Generation command-line arguments: -MIN_CROSSOVERS
Schematic Generation parameter file: /tmp/schOpts_spiceInPp65558
Simulator: spectre
Output Simulator: spectre
paramCaseValue: default
Language: Spectre
INFO (SPICEIN-56): Spice In failed to import the netlist file '/home/nick/fuses/TEF018BCD64X1PI5_layout.cdl'. You may like to read the log
file 'spiceIn.log' for details.
    Hi Nick,
    This might be a similar issue to one I found with CCR 2174246 (this is for my reference in case this comes up again) which was related to capacity limitations with schematic generation (there is definitely some work needed for this). You might want to try the "Generate Fast Schematic" option on the File->Import->SPICE schematic generation tab (if present). Which Virtuoso version are you using? (Help->About should tell you).
    I suspect we'll need to see the CDL netlist so you may be best contacting customer support.
