  3. Environment variables -> layout
  • Views 2761
blankman
blankman over 6 years ago
I am wondering where I would find a list of all the environment variables that can be set for layout, and in particular to find the variable to set grid type to "none"? I can never seem to locate from the user documentation.
Thanks!
Brian.
  • mbracht
    mbracht over 6 years ago
    Hi Brian,
    Getting an exhaustive list should be fairly easy - just go to
    CIW -> Options -> Save Defaults
    This brings up a GUI where you can choose a tool - layout in your case. And under "Variables to Save" you select "All Tool variables".
    Max
  • mbracht
    mbracht over 6 years ago in reply to mbracht
    and by the way - the layout variables controlling the grid appearance are drawDottedGridOn and drawGridOn
    Andrew Beckett over 6 years ago in reply to mbracht
    Also, in IC618/ICADVM181 there's now Options->cdsenv editor which is a searchable UI to do this kind of search. There's also (in the layout editor) the search assistant which can also be used to search for environment variables (search for "grid" for example).
  • blankman
    blankman over 6 years ago in reply to Andrew Beckett
    Thanks very much all, very helpful!
