  3. Create a PathSeg with "Part of a Route" as TRUE
  • Subscribers 150
  • Views 4067
Siddique baig
Siddique baig over 6 years ago
Hi All,
I am using Cadence ICADV 18.1 ISR8. I am creating a PathSeg using Skill with the following command:
dbCreatePathSeg(geGetEditCellView() car(leGetEntryLayer()) p1r p2r p1w "variable" "variable" '(0.0 0.0))
It does create a PathSeg in layout. But I see FALSE as "Part of a Route" in Edit Properties window as shown below:
When I create a wire using Create->Wiring->Wire from layout window, it creates a PathSeg with "Part of a Route" as TRUE. In both the cases, I don't have the connectivity for the net.
Please point me any option or a different command using SKILL to create a pathSeg or wire with "part of a route" as TRUE.
Baig
    Andrew Beckett over 6 years ago +1
    Hi Baig, You either need to find an existing route, or create a new one, and then add the pathSeg to that route. For example: ps=dbCreatePathSeg(cv "Metal2" 0:0 10:0 0.3 "truncate" "truncate") route…
    Hi Baig,
    route=dbCreateRoute(cv)
    route~>objects=list(ps)
  • Siddique baig
    Siddique baig over 6 years ago in reply to Andrew Beckett
    Thank you Andrew. It works fine Slight smile
