  3. How to get DSPF file path in ADE L by SKILL
  • Views 16670
XinjiePI
XinjiePI over 6 years ago
I have several DSPF files setup in ADE -> Setup -> Simulation Files. Is there a way I can use SKILL to get the path of these DSPF files and also know if these files are enable or not.
Thanks!
XJ
    Andrew Beckett over 6 years ago +1
    sess=asiGetCurrentSession() dspfFiles=asiGetEnvOptionVal(sess "allDspfFiles") This will return something like: ((t "/export/home/user/support/playGPDK45/fourinv.dspf" "") (nil "blah.dspf" "") ) The…
    The t or nil in each sublist indicates whether it is enabled or not; the next entry is the file, and the last is any options that have been chosen.
  • XinjiePI
    XinjiePI over 6 years ago in reply to Andrew Beckett
    Thanks Andrew. The command you gave is perfectly working!
  • XinjiePI
    I added these commands in a Skill program. But when I initial run the program. I see error:
    Error The default SKILL generic function has not been defined for the function "asiEnvGetVar". Ensure that this function is called with the correct argument (tool partition name).
    Appreciate your help to understand the Error.
    XJ
    Andrew Beckett over 6 years ago in reply to XinjiePI
    It probably means that the session you're passing to asiGetEnvOptionVal is nil and not a valid session object.
