  3. How to disable the field created by hiCreateLayerCyclicField...
  • Views 15859
How to disable the field created by hiCreateLayerCyclicField?
Quesar
Quesar over 6 years ago
This function seems a little "primitive" compared to most other form-related functions. Its options aren't named, and therefore unlike those functions, there is no "?enabled nil" option.
Thus, how would I disable it (have it greyed out) if I need to? Or is it not possible to do so?
My Virtuoso version is IC617ISR23. Any help would be appreciated, thanks.
    Use hiSetFieldEnabled after creating it:
    lc=hiCreateLayerCyclicField(tf "Layer" "" leGetValidLayerList(tf))
    hiSetFieldEnabled(lc nil)
    Or later from the form (this is assuming you have the default field name being used):
    hiSetFieldEnabled(CCFform->hiLayerField nil)
  • Quesar
    Quesar over 6 years ago in reply to Andrew Beckett
    Thanks a bunch Andrew!
