  3. To extract a sub list from a given list (of strings) which...
  • Replies 7
  • Views 19471
To extract a sub list from a given list (of strings) which matches a give string at the beginning
Sonu Chopra
Sonu Chopra over 6 years ago
I want to extract a sub-list from a given list which matches a given string at beginning
For Example :-
Given list   a = ("RM_1" "RM_2" "RM_5" "RM_6" "SRM_1" "SRM_5" "SRM_6" "M_5" "M_6")
                  b = "RM" (String to match to given list)
                Expected Output = ("RM_1" "RM_2" "RM_5" "RM_6")
I want String to match exactly at the beginning but at the end it can be anything.
I am referring to this Post  https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/38267/search-list-and-return-the-match-list but it also return ("SRM_1" "SRM_5" "SRM_6") which is not desired for me.
Can you please help me out on this point.
Regards
Sonu
  • mbracht
    mbracht over 6 years ago in reply to Sonu Chopra +1
    Not sure I understand this - in your example b is not a list but a variable containing the string that should be at the beginning of matching list elements. So correctly the setof() function should look…
  • mbracht
    b = (setof el a pcreMatchp( "^RM" el))
    Andrew Beckett over 6 years ago in reply to mbracht
    You could also use the substring function to pull out the first two characters of the list and use something like:
    b="RM"
    blen=strlen(b)
    result=setof(el a THEFUNCTION(el 1 blen)==blen)
    Please type substring where it says THEFUNCTION above - I can't post it because the word substring causes an issue with the forum software!
    This is beneficial if the string you're searching for contains any special characters what might be treated as magic by the regular expression approach that Max suggested.
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to mbracht
    Hello Max ,
    The issue is that list b is stored in some Variable and I don't know what is exactly inside list b . So , I can't use "^RM" Directly. This Example was just for Reference.
    Regards
    Sonu
  • mbracht
    Not sure I understand this - in your example b is not a list but a variable containing the string that should be at the beginning of matching list elements. So correctly the setof() function should look like this:
    a = '("RM_1" "RM_2" "RM_5" "RM_6" "SRM_1" "SRM_5" "SRM_6" "M_5" "M_6")
    b="RM"
    (setof el a (pcreMatchp (strcat "^" b) el))
    Max
  • Sonu Chopra
    Hello Max,
    Sorry there was a typo.. You are correct string is stored in Variable b.
    Your solutions work fine for me and thanks for all the help.
    Regards
    Sonu
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for the help and quick response.
    I think there is typo in above command (for result variable).. the correct command should be like that.
    result = setoff(el a THEFUNCTION(el 1 blen) == b)
    Please correct me if I am wrong.
    Note :- I am also facing issues while writing substring . THEFUNCTION should be replaced by substring.
    Please
    Regards
    Sonu
    Andrew Beckett over 6 years ago in reply to Sonu Chopra
    Yes, you’re right. It should be ==b not ==blen. By the way, yours had a typo too as it should be setof not setoff.
