  3. get cell Names from Nested Category
  • Subscribers 150
  • Views 15745
SrBraj
SrBraj over 6 years ago
I want the cell names of the category I have used the recursive call to the function categoryItem(); Below is the skill code I have written:
procedure( categoryItem(dvId catName tableGlobal tableGlobal2)
    let( (returnList)
        catTable = makeTable(strcat(catName "Tbl"))
        catNameTable = makeTable(strcat(catName "Tb2"))
        catId = ddCatFindCat( dvId catName "r")
        catMemberList = ddCatGetCatMembers(catId)
        catTable["cellNameList"] = '()
        tableGlobal2[catName] = '();nil
        foreach( catMemberListItem catMemberList
            if( memq("category" catMemberListItem) then
                categoryItem( dvId car(catMemberListItem) tableGlobal tableGlobal2)
                if( tableGlobal2[catName] then
                     setarray( tableGlobal2 catName cons(strcat(car(catMemberListItem) ) arrayref(tableGlobal2 catName)) )
                else
                     setarray( tableGlobal2 catName list(strcat(car(catMemberListItem) ) ) )
           else
                setarray( catTable "cellNameList" cons( car(catMemberListItem) arrayref( catTable "cellNameList" )))
      printf( "catName %s catTable %s\n" catName catTable)
      tableGlobal[catName] = catTable
      returnList = list( tableGlobal tableGlobal2 )
dvId = ddGetObj(<libName>)
tableGlobal = makeTable("glbl")
tableGlobal2 = makeTable("glbl2")
abc = categoryItem( dvId <category Name> tableGlobal tableGlobal2)
The printf output of the above code is mentioned below:
catName HV_MOS catTable ("cellNameList") table:HV_MOSTbl
catName HV_SJ catTable ("cellNameList") table:HV_SJTbl
catName IGBT catTable ("cellNameList") table:IGBTTbl
catName MOS catTable ("cellNameList") table:IGBTTbl
Notice the yellow highlighted lines, the two category names are assigned the same table handle(IGBTTbl). And because of this problem, the two categories are sharing the same cells.
MOS category in my Lib Manager has nested categories:
MOS-
    - HV_MOS
    - HV_SJ
    - IGBT
    Andrew Beckett over 6 years ago +1
    There are two main issues: You're using the memq function to check for strings in the sublist. You should never compare strings with eq (or memq) as odd things can happen. There's some caching of string…
  • SrBraj
    SrBraj over 6 years ago in reply to Andrew Beckett +1
    Thanks Andrew!! Code is giving the correct output now..
    1. You're using the memq function to check for strings in the sublist. You should never compare strings with eq (or memq) as odd things can happen. There's some caching of string objects to minimise duplication, but you cannot guarantee that eq/memq will see two identically-valued strings will be the same unless they originated from the same source. In practice, eq should only be used with symbols and lists (and again, with lists you know you're comparing pointers, not the values in the list). So this should use member() not memq(). I'd have probably used cadr(catMemberListItem)=="category" rather than member or memq. Because of the memq my first attempt to run your code did not recursively call categoryItem.
    2. The other big problem is that you didn't put catTable in the let, so it's global - and the recursive call overwrites the catTable in the level above - hence your issue.
    Here's the updated code. Note that you could also avoid assigning returnList because you never use it - the last line in the code could just be list( tableGlobal tableGlobal2 ) without the assignment. Similarly catNameTable is assigned to but never used.
        ; ANDREW - declare variables as local
        ; note that catNameTable and returnList are not really used (last statement doesn't need to
        ; be an assignment)
        let( (returnList catTable catNameTable catId catMemberList)
    ;	printf("DEBUG: %L\n" catMemberListItem)
    	    ; ANDREW - DO NOT USE memq for comparing strings. Use member instead
                if( member("category" catMemberListItem) then
                    else
               else
    dvId = ddGetObj("analogLib")
    abc = categoryItem( dvId "Sources" tableGlobal tableGlobal2)
  • SrBraj
