  3. Title of tearoff menu
  • Views 15598
drdanmc
drdanmc over 6 years ago
IC617:
I created a pulldown menu with
menu=hiCreatePulldownMenu('my_sym my_title my_items)
and when I insert it with
hiInsertBannerMenu(win menu hiGetNumMenus(win))
all is well, I see the menu, and if I tear it off I see the tear off menu with the title specified by the my_title string variable.  Then I tried
my_title = hiLoadIconData("/path/to/icon.png")
and repeat the above.  Now my custom pulldown menu is an icon as desired, but if I tear off the menu, the menu dialog is called "iconTitle".  I don't seem to see a place to specify both the name *and* an icon.
If I check menu->_menuTitle I see (98566377 16 16) which should be my icon ID and WxH.
So... what's the magic to get the right name in the tear off menu title bar?
-Dan
    Hi Dan,
    I can't see a way of doing this. I think you should contact customer support - this will probably need R&D to provide a function to do this, or extend the icon description to allow a title as part of the icon description.
    If you contact customer support, please post the number here as I will be interested in seeing the CCR (change request). Not something I've ever needed to do (have an icon for a pulldown menu), but I'm interested nevertheless.
  • drdanmc
    drdanmc over 6 years ago in reply to Andrew Beckett
    Thanks.  I submitted a SR along with a complete, self contained, SKILL example.  I'll update if/when they convert to a CCR.
  • drdanmc
    drdanmc over 6 years ago in reply to drdanmc
     CCR#2247533
    -Dan
