  3. How to get form handle using window and form name
  • Views 16149
alexstepanov75
alexstepanov75 over 6 years ago
I create a window with some form. I have also function registered with hiRegCloseProc to this window. This function gets the window as its argument. How can I get form handle using the window?
For example when creating window with form
win=hiCreateWindow(
  list(100:100 500:500)
  "form"
  "muwindow"
  nil
  myForm
);hiCreateWindow
hiRegCloseProc(win 'myCloseProc)
And then
procedure( myCloseProc(win)
;how to get form handle here using win and form name
);proc ATCopyCellsByListFileGUICloseProc
    Andrew Beckett over 6 years ago in reply to skillUser +1
    You can use win->hiForm to get the form name, and if you need the form object itself, you'd use symeval(win->hiForm). So there's no need to store an object on the window structure - it's already linked…
  • skillUser
    skillUser over 6 years ago
    Hi Alex,
    You could store the form handle on the window structure (when you create the form, for example) and then you have access to it from you close proc, no guessing needed (e.g. hiGetCurrentForm() ).
    Best regards,
    Lawrence.
    You can use win->hiForm to get the form name, and if you need the form object itself, you'd use symeval(win->hiForm). So there's no need to store an object on the window structure - it's already linked by virtue of creating a window form...
